Montana tractor keeps dying
   / Montana tractor keeps dying #1
Kevvy123*
Montana 3040
Hello, I have a Montana 3040 tractor that starts up fine but just about when you go to use it I hear a click noise down by my right foot and the engine shuts down. Ive been told its probably a solenoid but that was replaced and it still does the same. Cant really use the tractor if I cant depend on it to keep running. sometimes it dies in a few seconds, other times 10 to 20 minutes after starting. Anybody have ideas or suggestions?
thanks in advance.
Kevin
   / Montana tractor keeps dying #2
The fuel solenoid may be getting shut down by one of several possible safety switches. Depending on your symptoms, switches to look at could be seat, hst pedal, pto, or clutch.
I would start with the seat switch.
   / Montana tractor keeps dying #3
Does fuel take have vent could be plug?
Air Filter clean?
   / Montana tractor keeps dying #4
I started having a similar problem with my old Same 35. It would sometimes shut off for no reason, sometimes cold, sometimes hot. As I dug into the wiring diagram and studied things, the fuel solenoid shutoff is controlled by an electrical "box" circuit. It is normally "off" while running. The solenoid typically has a spring and is in the ON position (i.e., not shut off). When you turn the key on, it starts a cycle in the "box", and when the key is shut off, the box cycles and sends voltage to the selenoid, shutting off the fuel, but only for a period of time, say 20 sec or whatever the design is. After that, the fuel solenoid voltage stops and solenoid opens back up to it normal "run" position (no voltage).
On mine, I had a frayed wire that would intermittently, briefly interrupt voltage to the "box", which would then send voltage to the fuel solenoid, as though the key had been shut off. So in other words, any brief electrical signal interruptions will tell the box to sent voltage to the solenoid and shut it off. Half a minute later, the tractor will start right back up with nothing wrong. So this can be a frustrating problem. An easy way to check it is to find the fuel solenoid. It should have two wires going to it. Just disconnect one of the wires to break the circuit. The solenoid will remain in its normally open position, and the tractor will start and run just fine. Of course, shutting the key off will have no effect. But you can reconnect the solenoid, cycle the key on and off, and you should see the solenoid activate and close. Later, it will click and re-open, after the engine has stopped.
As Rj suggested above, one of the several safety interlock circuits are probably fritzy, and sending a signal to the black box to shut off. You'll just have to track which one, by disconnecting the clutch, brake or whatever else one at a time to see where it is coming from. Or, theoretically you can just disconnect the solenoid wire, run the tractor, then reconnect it and shut it down with a key cycle when done (not highly recommended).
   / Montana tractor keeps dying #5
Have you tried the Montana section of the forum?
Just a thought.
Hey thanks for that info. I have it at a tractor shop now. I explained the problem over the phone before I went through the hassel of hauling it in. It literally fired up and then shutdown while it was still on the flatbed trailer. He used his fork lift to tow it off the trailer. a week later I called for any update and he said it fires up everytime and I have ran it around the shop and lot for about 20 min. and its never clicked and died. He mentioned safety switches too but said there were several and wasnt sure which one. Cant he just change or over-ride them? Hes the mechanic... why am I having to quiz him on how to fix it? Very frustrated. But again thank you for your info. I will share it with the mechanic. LOL
Kevin
   / Montana tractor keeps dying #9
Pretty sure that was made by LS. It may help to check in that group as well. It is probably substantially the same as an LS model from that timeframe.
   / Montana tractor keeps dying #10
Depends on the year. They started out independent, but eventually did sell to LS.
I knew the local dealer from when he owned a transmission shop which is why I didn't look at them when shopping.
He's the kind of guy that if he shakes your hand, you'd better count your fingers to make sure that you get all of them back.
1701 (A58375)
1701 (A58375)
UNKNOWN  500BBL WHEELED FRAC TANK (A58214)
UNKNOWN 500BBL...
FENCE PANELS (A58216)
FUEL CELL TOOLBOX COMBO (A58214)
FUEL CELL TOOLBOX...
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2008 PJ 32 FLATBED GOOSENECK (A58216)
2008 PJ 32 FLATBED...
