Good morning!!!!
   / Good morning!!!! #211,132
Thanks, Kyle. Nothing new. Dr told me shortly after I retired that I had asthma, have had inhalers ever since of various brands. earlier this year, VA said i didn’t have asthma, have COPD. Will be interesting what I’m told as result of this PFT.
Well regardless of the label, I hope that it turns out well.
FWIW: I use a half mask P100 when out mowing or doing anything with dust (wood, soil, spray paint, or metal). They have at least ten times the efficacy of the disposable masks. I've been thinking of upgrading to a PAPR for when things are really ugly here (e.g. wildfire smoke). It isn't much gain on filtration, but a big reduction in lung effort when using filters for VOCs.
Happy Monday to all!
All the best, Peter
   / Good morning!!!! #211,133
Good morning! Low of 52°, heading towards the 80° mark. No chance of precipitation.
Ron, ouch.... hope you heal quickly.
David, hope the PFT results are good.
Today's agenda is to troubleshoot the pesky trailer lights. Apparently, Ram has had issues with the 7 pin and 4 way plugs on the trucks not making good connections. I think that I'll start there....
Still need to finish the weed destruction, hopefully can get some of that done.
Everyone have a great day!
   / Good morning!!!! #211,134
Once a year I spray mine out with contact cleaner and reinstall dielectric grease. Seems to help a bunch.
   / Good morning!!!! #211,135
Same. I have two large batteries on my trailer that power the winch, and a trailer-mounted charger made for dump trailers, that recharges the trailer batteries off the truck. That charger pulls a continuous 20A while topping off the batteries or while winching, and I used to have some issues with 7-pin connectors overheating and melting as they'd age, almost certainly due to contact plating oxidation.
So a few years back, I started packing my 7-pin connector with dielectric grease about once per year, and have had zero problems ever since. Dielectric grease keeps moisture and oxygen off those critical contacts, and doesn't seem to cause any problems for the nylon connector or PVC insulation.
   / Good morning!!!! #211,137
66°F and no rain.
Looks like Kiko may pass us by with minimal to no effects. The was hope for some rain relief.
Likely get a few hours mowing.
HH in town this afternoon.
Prayers for all
Be safe
Have a great w
   / Good morning!!!! #211,138
finished being domestic, got the floors vacuumed and vinyl mopped and waxed.
time to go outside and putter
my next car project is to install this aftermarket secondary air injection pump air filter.
The oem one is foam inside a box and the foam falls apart over time.
Instead they say take the foam out and install this on the intake.
looks like it should last forever.
gives the dealership techs something to gawk at...what is that alien part?
the joys of being out of warranty, do what you want.
thankfully there are several very clear and very easy you tube videos showing how to take the old
one apart and add this one. Plus it looks good, like a serious filter should look. ;)
19 bucks and washable, a K&N clone.
202481 (A54757)
202481 (A54757)
Land Pride FDR1660 (A53317)
Land Pride FDR1660...
utv cart Honda (A56857)
utv cart Honda...
2018 HINO CONVENTIONAL TYPE TRUCK (A55745)
2018 HINO...
2022 Horizon Trailers DH8BP-2 15ft 5 Ton T/A Dump Trailer (A55973)
2022 Horizon...
2022 Caterpillar 300.9D Mini Excavator (A55973)
2022 Caterpillar...
