BX2200 -- will almost start
/ BX2200 -- will almost start #1
terpdog
Member
Marriottsville, Maryland
Kubota BX 2200
The tractor will "almost start" will puff smoke out of the front exhaust, will crank and "almost" fire all the way. I have a little over 1000 hours on it and it is about 20 years old.
1) I checked the fuel(it is coming out fine when I turn the key) fuel filters seem ok.
2) Air filter is ok
3) Start Stop solonoid is ok(that would just click and I've replaced that)
4) Battery is full on charged(it is new)
5) Starter seems fine(but maybe that is the problem?)
I want to say next is glo-plugs but it's in the 70's and maybe it is maybe not?
Wanted to get some thoughts I haven't ever replaced the glo plugs but it hasn't been that cold(but maybe I'm totally wrong on this one).
Anything else I can check or do? I wasn't going to just throw parts at it but before getting the dealer to do the pickup($$$$) all by itself may be worth it.
/ BX2200 -- will almost start #4
Sounds like you have air and fuel.
How old is your battery, maybe it is just tired and cant spin the engine fast enough?
I actually replaced that first(it's in good shape right now). I thought that was the problem because it was 5 years old.
/ BX2200 -- will almost start #6
I had done that
I've loosened the nut and while starting I don't see any air just flows out.
Don’t just try starting after opening the bleeder screw on top of fuel filter.
Typically need to do this if machine has been run out of fuel or if it has not been run for an extended period of time.
Modern Kubota BX models, including the BX2200, typically have a self-priming electric fuel pump. If you run out of fuel, follow these steps:
  1. Refill the fuel tank. Add a sufficient amount of fresh, clean diesel fuel.
  2. Turn the key to the "On" position for about 30 seconds. Do not crank the engine yet. You should hear the electric fuel pump working to circulate fuel and purge air from the lines.
  3. Start the engine and let it run for about 30 seconds. It may run a bit rough at first, but it should smooth out as the last of the air is pushed through.
If the tractor still won't start after using the self-priming pump:
  1. Loosen the bleeder screw on top of the fuel filter housing.
  2. Turn the key to the "On" position until clean, bubble-free fuel flows out of the bleeder.
  3. Tighten the bleeder screw.
  4. If it still doesn't start, you may need to loosen the injector lines at the injectors themselves. Crank the engine until fuel sputters from each line, then retighten them.
I'll give a few of those a try, I didn't run out of fuel just checked things out.. but maybe something.. should I turn it past the glo plug piece? I assume yes.
I did give that a shot, I did hear the glo-plug clicking but not sure about the electirc fuel pump.. i did "smell something like something was burning(ish)"
/ BX2200 -- will almost start #8
Is a 20 year old tractor considered "modern" ????
/ BX2200 -- will almost start #9
Make sure the compression release lever releases the compression release.
/ BX2200 -- will almost start #11
Did you use the glow plugs at all? True that in warm weather you don't need them much but you do need to let the glow plugs run a few seconds before trying to start it.
How long since it was running?
Yes I did.. and it was running last week. I use it for mowing and I used it last Monday, went out on FRiday and it wouldn't start(fully).. figured.. darn it battery(it was 5 years old) got a new battery, cleaned up the connections.. but didn't start.
Then I checked fuel(made sure it was pumping, and it seems to be fine). Plenty of fuel in the tank. Just won't kick over and if I let it go.. a slight burning smell and small puffs of smoke out the exhaust.
not sure if the file but this is what it sounds like, does. Maybe this link can work?
/ BX2200 -- will almost start #14
From that video your engine is turning over very quickly, not a battery problem there. I'd say your not getting fuel but you said you have loosened an injector and fuel comes out without any sign of air.
/ BX2200 -- will almost start #15
Only thing that comes to mind is the stop solenoid. I had one that would not retract all the way and did some weird stuff like that. Had a bad gasket and water got into the solenoid body. You can remove it (2 screws) and try to start, if it does be ready to shove it back into the hole (unplugged) to stop the motor... or your can stick something else into hole to push the plunger.
/ BX2200 -- will almost start #16
/ BX2200 -- will almost start #17
There should be a key position just prior to cranking where the glow plugs are automatically energized. A light on the panel indicates power is applied to the glow plugs. In cool weather hold it there for a few seconds to build some heat before you start cranking. It should start quickly.
i have checked the fuel as much as I know how and it seems pretty good.. when I loosen that nut it just comes out pretty well, just pours out when trying to start.
I'm going to test the glow plugs next. The local shop says they are a wear out item and after 20 years and 1000+ hours it may be time.
I've replaced that before and usually it was a "click" but wouldn't even turn over.
/ BX2200 -- will almost start #20
I think there are 2 coils in the fuel stop solenoid. One is energized while starting, and the other is energized while running). Could be the run coil is fubar.
The tractor should start and run with the solenoid removed.
2012 PETERBILT 348 (A67714)
2012 PETERBILT 348...
2016 Chevrolet Silverado 2500HD 4x4 Crew Cab Knapheide Service Truck (A68183)
2016 Chevrolet...
CAT 973 GP Bucket (A68134)
CAT 973 GP Bucket...
2012 FORD F-550 CAB AND CHASSIS (A67714)
2012 FORD F-550...
2004 Mack Vision (A64911)
2004 Mack Vision...
TWO PALLETS OF HYD TANK, V8 ENGINE BLOCK/PARTS (A68842)
TWO PALLETS OF HYD...
