Grease trailer sleeve coupler
/ Grease trailer sleeve coupler #1
azuerch
Member
2021 Kioti NX4510
Hello I have a PJ 12ft utility trailer that has a slide style sleeve coupler. It has become increasing difficult to lock/unlock the coupler and I'm not sure how to grease or oil it. The style is like this:
It only slides maybe and inch or so (by design) and there's no want to disassemble it that I can tell to clean and grease it up good. I can spray something like WD40 under the sleeve but I'd like to use something that will stick and last longer but there isn't much of an gap to spray into and it neesd to penetrate fairly deeply. Any recommendations?
/ Grease trailer sleeve coupler #3
WD40 is not a lube. I'd ask/call PJ themselves.
/ Grease trailer sleeve coupler #4
You could try a motorcycle chain lubricant. There's also lithium grease in a spray can.
/ Grease trailer sleeve coupler #8
I use graphite spray on my hitch shank and white grease on the ball. While graphite in spray form will rub off, some does remain. I don't know if it would work it's way inside of the slide on your "bulldog" coupler or not?
/ Grease trailer sleeve coupler #9
It is most likely a build up of grit and garbage. Brake clean or WD while exercising it, then a powdered graphite to lube it. And grease or oil is going to attract dirt and dust and gum the works up.
/ Grease trailer sleeve coupler #10
/ Grease trailer sleeve coupler #11
I never use anything for last 20+ years. Been towing all my life.
Found that when I used something, it just attracted dirt.
/ Grease trailer sleeve coupler #12
That looks about the same as the T9 in my post above, except in spray form.
Goes on wet and dries in seconds.
If it works on motorcycle chains, it ought to be good for a slide style sleeve coupler on a trailer hitch.
  • Good Post
Reactions: D&D
/ Grease trailer sleeve coupler #13
Same. Used some Fluid Film on one once. Thought being it would last longer. Made to messy too work with and attracted dirt until it wore off.
/ Grease trailer sleeve coupler #14
The strongest coupler out there. I never lube mine. The first thing I do when I unhook is take my jack block and tap the sleeve. Loosens right up and then it operates easy.
Thanks for all the suggestions. I did contact PJ trailers via the question form on their website and never heard back. That was many months ago
/ Grease trailer sleeve coupler #16
IMO, I use this for the slide
and this on the ball
/ Grease trailer sleeve coupler #18
If it's an original, yes, but I got a copy (guess the patent expired) on a trailer and it was not good at all.
Fixed it by converting to a tow ring, like I do on most bumper pull trailers that doesn't need a WD hitch.
/ Grease trailer sleeve coupler #19
Try here:
Bruce
2007 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A61568)
2007 Dodge Ram...
JOHN DEERE 7330 PREMIUM TRACTOR (A62130)
JOHN DEERE 7330...
Pallet of Forks (A61567)
Pallet of Forks...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A63276)
KNOW BEFORE YOU...
Atspower Mini Excavator (A60352)
Atspower Mini...
2022 John Deere Z920M Zero Turn (A63116)
2022 John Deere...
