12 States to ban diesel vehicles
/ 12 States to ban diesel vehicles #241
In many ways we're already there. Both sides are equally guilty of this...taking extreme positions on issues and then refusing to budge or compromise. Hopefully, we're not so far along this path that we'll never recover.
When it comes to open borders versus closed borders/legal immigration, I know which side common sense side I support and which criminal/chaos side I don’t support. I don’t view my sides closed borders/legal immigration anything near the definition of “extreme”. OTOH, Open borders is dangerously “extreme”
Speaking of EVs, I see another automaker is scaling back on them citing weak demand.
Its because
1. they won’t “save the planet”
2. few Americans can own one because of their charging & range limitations.
3. anti-Elon Musk lunatics vandalizing them.
/ 12 States to ban diesel vehicles #242
gound source heat pumps are not common here just plain air to air work well in our climate and are much cheaper to install my power bill is low because heating is by a log burner
Get ready to throw out that CO2 generating Log burner and only use the approved electric heat powered by renewable clean electricity. Just don't look at the CO2 involved in building that clean power.
Now since you started it, how can you use an evil and verboten heat source. Wood burning is one the first things to be outlawed to save the planet, well unless it is done in massive scale as renewable energy. Next you are going to admit you have out door fires and might burn none clean things, like paper or other waste that 😳 was contaminated by any petroleum product..... like a paper towel you wiped your hands with....
I use wood heat as well, live within millions of acres of oak and hickory dominated forrest,
/ 12 States to ban diesel vehicles #243
Its because
The last one is very real here where Tesla started.
I have a high school teacher friend who really likes his Tesla which had gone from really cool a few years back to now getting snide remarks and damage…
He is just one of several in similar situations.
Sad in America in 2025 there are those that feel not guilt destroying the property of others to send a messsge.
/ 12 States to ban diesel vehicles #244
If you change out a window or sand the house trim to make ready to paint someone might very well call to make sure it’s done properly…
The tractor is about something could be getting ready to be built… where are the permits, etc…
Each year I have to freshen up our mandated fire trails… maintenance does not require a permit… but every couple of years someone makes the call…
And brother I'm begging you to please, please, PLEASE keep those folks
in place, at home, in California. 90% of the rest of the country will thank
you.
/ 12 States to ban diesel vehicles #245
you.
The line of u-hauls is long…
It’s at least 50/50 if not higher planning on leaving the SF Bay Area… many upon retirement… some can’t wait.
My last work trip was enlightening as people met were friendly, public spaces well kept, markedly less trash along the roadside and cost of dining out and gas significantly less…
It was hot around 100 but the dry desert heat was not bad.
I’m starting to think it’s a big city thinking verses not big city… not seeing s lot of difference between say Seattle, Portland and San Francisco.
As mentioned rolling coal came as a surprise… just not going to see that here…
/ 12 States to ban diesel vehicles #246
you.
We don't need them here either. It's bad enough with the ones we already have.
/ 12 States to ban diesel vehicles #247
Seems rules for thee but not for me is his platform? Yup there is a lot of hypocrisy in these green advocates (for someone else). He has outed himself several times but his bandwagon must have several spare wheels because he just keeps rolling along.
add: the heat pump conversation, The air heat pumps might keep a moderate climate home warm, but mine is used for spring and summer (great for cooling)...winter is all about our trusty wood stove, that works just as well when the power is off. Old bones love dry wood heat in the wintertime.
one note about Co2....a non toxic odorless gas that is essential for life on earth. We mitigate bad pollutants such as sulfur dioxide, particulates, and nitrogen dioxide with the end result being more Co2.....and even at that man caused co2 is less than .3 % of our atmosphere. So blowing up economies for green energy conversion doesn't seem to the fit the science. Could it be that the sun is warming the planet and the natural carbon cycle is just part of something we have little if any control over? Climate change has been around for 4.5 billion years.
/ 12 States to ban diesel vehicles #248
Completely different process.
Does not produce the waste of nuclear fission.
Fission derives heat from splitting atoms.
Fusion combines atoms.
Molten salt reactor, or Thorium reactor:
A conventional fission reactor only uses 2% of the energy in uranium, the other 98% is radioactive waste. Just getting new Uranium is cheaper than processing the used uranium to go for another cycle.
A molten salt reactor can use up all the existing nuclear waste up, meaning that when after 40 years of running a conventional reactor, and the reactor needs replacement, we can produce the same amount of energy in a molten salt reactor for the next 2000 years, on the waste of said conventional reactor.
Another plus is the auto shutoff: in the bottom of the molten salt circuit is a pipe connected to a holding tank. In this pipe, a cooling element is installed that plugs up the drain pipe with cool, solid salt.
So when the control room looses power, the freeze plug thaws, the molten salt drains into the reservoir and the nuclear reaction is instantly stopped.
So, why isnt every nuclear reactor in the world a molten salt type, and was the experimental molten salt reactor abandoned in the early 70s ?
A. Because salt is corrosive and high temperature accelerate chemical reactions (like corrosion). Back then, allloys like Inconel didnt exist yet, metallurgy has come a long way since then.
B. In the 60s, the US army needed Uranium to make nukes for the arms race. Molten salt (thorium) reactors did not produce uranium that is used in weapons.
And while we are quabbling with the green movement about winmills and solar panels (made in China) China already lurches ahead of us with MSR
/ 12 States to ban diesel vehicles #249
Yes
It’s called transmutation.
Basically, they utilize a method called Fast fission and are able to absorb and utilize the fuel rods that were considered nuclear waste and stored away presently
There is also a type of plant (msr’s or molten salt reactors) utilizing molten salt instead of solid fuel where the superheated chloride causes atoms to split.
Ah, you already mentioned MSR... 👍
/ 12 States to ban diesel vehicles #250
Locally, it's hard to find someone that can work on a geothermal heat pump. And if you purchased a home warranty, good luck filing a claim on it. It's pretty much a guarantee that they don't have a contractor that can work on them.
Same problem in Holland. Heat pump and solar panels are mandatory to get permission to build a new house, yet theres no one to service it if it breaks down. And solar panel companies go bankrupt one after another because the market collapsed since energy companies charge a backfeeding fee if you backfeed your excess solar into the grid
And yes they are right to do so. Energy plants produce 10 kilovolt, distribute it long distanve through above ground cables, to local 1Kv transformers on a city scale, and then every few blocks share a transformer that transforms it to 240V single phase or 400V three phase (in Europe)
And the government thought it was a good idea on a sunny day to feed the same amount of energy back into the grid at end-user voltage... Anyone remember Ohms law, I=U/R ?? 🙈🙈🙈
/ 12 States to ban diesel vehicles #251
It's similar here with solar. You pay big money for an install thinking your going green. Financed it.... with funny fine print and weird interest rates.
Company does a half arsed job on the install, doesn't have it wired correctly.
Then goes out of buisiness and your stuck with a mess and payments on system that doesn't work.
Best case is you get a decent install. But your still got some loopy financing with payments fixing to double in a few years.
Then good luck selling the place and getting someone to take over your green financial headache attached to your home.
Power companies pay you pennies on the wholesale price for the power you put back to the grid. So that incentive is gone as well.
/ 12 States to ban diesel vehicles #252
I don’t have a negative to report with my 2008 panels totaling 6kW
No financing and owned system with ground mount…
The ground mount was surprisingly very expensive but it’s a one time cost and keeps the panels off of my tile roof and tanks less than a minute twice a year to switch between winter and summer sun angle…
Pull the clevis pin and tilt to the other slot and replace the pin.
/ 12 States to ban diesel vehicles #253
I can understand that. Residential installations are penny-ante compared to a real electric supplier. Probably negative return for the the utility in the end with all the paperwork involved. Why should regular customers subsidize those with solar installations?
/ 12 States to ban diesel vehicles #254
I wasn't disagreeing with you on that part of it.
The results are similar as to overseas by comparison when it comes to solar.
A bunch of fly by night cowboys installing one day and out of buisiness the next.
Leaving the gullible in the lurch.
/ 12 States to ban diesel vehicles #255
My commercial electric rate is better than anything residential.
Utility is very much pushing solar with grants to public schools, etc.
It does seem odd solar is a detriment while at the same time utility and lawmakers and regulators encourage it?
As solar started becoming popular the utility said it hoped those coming online will be enough to retire old hydro and avoid new hydro…
/ 12 States to ban diesel vehicles #256
They pushed solar here for a while with incentives... paid for by those of us who didn't jump on the bandwagon. The results far exceeded their goals. Now some are upset because incentives have ended.
/ 12 States to ban diesel vehicles #258
Regardless of one's opinion on fuel economy, allowing one state to dictate rules on interstate commerce violates the constitution.
As for an earlier comment about being one country...we have never been. The US is a collection of 50 countries who abrogated a piece of their sovereignty to improve their defense and trade options.
"One nation, under God..." - a nation is a group of people with a shared background. We tend to use country and nation interchangeably. They are not the same.
/ 12 States to ban diesel vehicles #259
You can thank the left subsidized media for this.
Along with all the free loaders the politicians have created.
/ 12 States to ban diesel vehicles #260
Not until the outer worldly aliens attack.
WHISPERWATT DIESEL POWERED AC GENERATOR (A60736)
WHISPERWATT DIESEL...
2023 WRANGLER 5500T ARTICULATED WHEEL LOADER (A58214)
2023 WRANGLER...
2023  FREIGHTLINER M2 22FT NON CDL BOX TRUCK (A59905)
2023 FREIGHTLINER...
Caterpillar 72" Quick Attach Bucket (A60462)
Caterpillar 72"...
FORD 6610 TRACTOR (A59823)
FORD 6610 TRACTOR...
2019 CATERPILLAR 5K FORKLIFT GP25N (A60736)
2019 CATERPILLAR...
