Gambled on a G5200 Today
/ Gambled on a G5200 Today #21
What are you expecting the "Sea Foam" to do?
Never used it myself.
I'm not sure if your question is one of genuine curiosity, but I'll answer as if it is.
Since I don't know the history of this tractor, my use of Sea Foam is just an extra step to the full service. Although I will be pulling and cleaning the tank, Sea Foam may or may not help address any buildup in the lines and injectors. Likewise, Sea Foam may or may not help break down engine sludge prior to changing the oil.
Other than that, I've used it as a fuel stabilizer and through vacuum/intake lines on gasoline engines and I feel it does a good job at reducing carbon buildup. YMMV.
/ Gambled on a G5200 Today #23
I swapped out the glow plugs earlier today and it fired right up. The glow plug indicator lamp still doesn't work, but I haven't had a chance to get into the dash wiring yet.
Excellent!
/ Gambled on a G5200 Today #25
Seafoam into an old engine can overwhelm the oil filter with dislodged "crud".
I killed an Audi A8 with that stuff!
/ Gambled on a G5200 Today #26
Oh yeah I guess I did not read the post with SeaFoam I thought the addition would be in the fuel not the oil. I would NEVER EVER put that in the oil of any engine
/ Gambled on a G5200 Today #27
It's a parallel circuit, not in series, it is also a light, not the older style heater coil type.
The glow plugs can still work without the light working.
The glow plugs do, indeed, function independently from the indicator. On the G5200, the indicator is a coil rather than a light. I still haven't been "under the dash", but it looks like the part is about $60 if it's actually bad and not just disconnected.
/ Gambled on a G5200 Today #29
That weird, maybe someone changed mine out, although it was burned pretty good before I got it so who knows whats been done to it.
/ Gambled on a G5200 Today #30
Do you mean it's like this - if so these can be found on the eBay for about $13 + mailing
(Search: glow plug resistor indicator)
I was actually referencing the price for the whole indicator assembly specific to the tractor. It's good to know the resistor can be sourced separately.
Giyi GY-QSJ Mini QA Broom Sweeper (A60463)
Giyi GY-QSJ Mini...
500BBL WHEELED...
Le Roi 80-Gallon Air Compressor, 220 Volts (A59076)
Le Roi 80-Gallon...
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A58216)
2014 MAGNUM...
2011 TROXELL 140BBL TRI AXLE VACUUM TRAILER (A60736)
2011 TROXELL...
1995 John Deere 5300 (A60462)
1995 John Deere...
