Weed wacker - extending string life
/ Weed wacker - extending string life #121
my take on this design is that it's designed for homeowners who only whack occasionally. no way will i shut off trimmer, remove harness & refit trimmer string. plus wonder how much waste of line it would be for unused line. strictly bump for me if properly wound, my workload is too much to use this type design
/ Weed wacker - extending string life #122
my take on your take is that you don't whack heavy stuff and can manage to get by on a little string
/ Weed wacker - extending string life #123
welcome to try out my workload. whacking heavy stuff does not mean thick line only. has to do with available power & properly wound line. don't have time to stop & reload every time.. how many commercial applications do you see with this type head?
when i want heavy duty weed whacking in thick material, i go with top of line pro trimmer and adequate string delivery system. it's not just about thick line my friend. each to his own, regards
/ Weed wacker - extending string life #124
welcome to try out my workload. don't have time to stop & reload every time.. how many commercial applications do you see with this type head?
happy whacking to ya with your thick line. when i want heavy duty, i go with top of line trimmer, not stiff & thick line. each to his own, regards
Prior to having a Speed Feed head I probably would have preferred the head with replaceable pieces, Speed Feed is a game changer, especially if you are trimming against rough edges like concrete/stone/asphalt and wearing down the line quickly.
/ Weed wacker - extending string life #125
The rare homeowners using Ø.155" diameter line? :p
I'm also only ever using bump heads, they're just too convenient for what I'm doing, and I don't need super heavy duty trimmer lines for most of my chores.
But when the Speed Feed max's out at Ø.095" line, and the Stihl 25-2 max's out at Ø.105", what are you going to use with your heavy-duty lines? I think that's the main appeal of the FixCut 31-2, which is spec'd to carry Ø.135" or Ø.155".
I'd also guess there's a lot less line replacement happening, when you're swinging something that fat thru most grasses and weeds.
/ Weed wacker - extending string life #126
I use the Echo hand held trimmer with 0.95 line for normal lawn and light weed cutting. But for weeds with heavy stalks and other heavy uses, I get out my Echo wheeled trimmer that uses 1.55 diameter line. That thing is a beast. It has a Honda 4 cycle engine that makes short work of trimming heavy vegetation.
/ Weed wacker - extending string life #127
Someone gave me a Ryobi battery-powered trimmer they didn't need any more; that's got spools of something light. Works great around the lawn. For heavier stuff the old Echo gets used with either the 155 line or a blade. I'm sure if I was a yard care specialist I'd use the bump feeds as well but we had terrible performance with anything less than .155 here.
/ Weed wacker - extending string life #128
jyoutz: sounds like a useful tool, never tried that type. am sure it has it's place.
in terms of tractors & trimmers....just think of the options we now have compared 40-50 yrs ago when i got started with my property. glad it works for you
/ Weed wacker - extending string life #129
When I cut brush, I use the brush cutter head. It is far superior to line for brush.
Brush, for me can be over 6' tall and an inch in diameter. Not small trees (though it handles those well, too), some weeds out here get huge when left alone for a couple of months.
/ Weed wacker - extending string life #130
Have a blade that looks similar to a triangle for heavy weeds and can be sharpened with a file, switch to 10" carbide tipped blade when going gets tough. Only use that couple times a year at farm. Around house a small trimmer handles most of trimming
/ Weed wacker - extending string life #131
I'm hoping the 780 ft spool of .095 square line I bought for my Stihl will flow thru the new Speed Feed 400 head I just bought. The line isn't that expensive, less than the cost of the Speed Feed head, but I hate throwing away anything that's perfectly good and useable.
/ Weed wacker - extending string life #132
Any string size 0.95 or less I’ve used on the Echo speed feed head works fine.
/ Weed wacker - extending string life #134
Big strings really work well when you got serious weeds and tree shoots to knock down but I'd not recommend it when you have plants, furniture or buildings you don't want to damage. Hope that makes sense. We run 155 in the field and usually 105 string at home on a bump head.
/ Weed wacker - extending string life #135
I guess one advantage of the speed feed head is that, with it being so much faster and easier to load, there's less incentive to always buy the largest line your trimmer head can handle.
They also likely hold more length of a smaller line, which becomes a PITA to load on a traditional head, but easy to load into the Speed Feed.
/ Weed wacker - extending string life #136
Sounds like mine. It's for my Dewalt unit. I have a saw blade option I bought online, but didn't fit my old trimmer. I should see if it will work on this one.
/ Weed wacker - extending string life #137
My Stihl cutter takes a 1" arbor hole but most blades also come with an adapter that takes it to 20mm. I have cut saplings over 2" with the carbide blade. Hitting an occasional rock doesn't seem to dull them much
/ Weed wacker - extending string life #138
The Shindawa Speed-Feed 400 head I just bought says it will take 20' of .095, and .105 max.
My live-at-home 37 yr old son (long story) does most of the trimming and was slightly aggravated. He's been running the DeWalt for about 4 years now and just got loading the Husky T25 loading down pat. :)
/ Weed wacker - extending string life #139
I've got the 3 yellow blades on my weedwacker, I change them maybe once or twice a year. They're cheap and last a really long time unless i'm hitting something like concrete.
/ Weed wacker - extending string life #140
2026 DEVELON DX27Z-7 EXCAVATOR (A65053)
2026 DEVELON...
2019 Ford F-150XL (A60462)
2019 Ford F-150XL...
Landhonor Skid Steer 3Pt Hitch Adapter (A62679)
Landhonor Skid...
Bell 500 Gallon Saddle Tank (A64119)
Bell 500 Gallon...
2017 BX2680 Sub Compact Utility Tractor (A63688)
2017 BX2680 Sub...
2017 Dodge Grand Caravan Van (A61574)
2017 Dodge Grand...
