Grease - is there no better way? Can we talk about this?
/ Grease - is there no better way? Can we talk about this? #161
Almost applied for a factory union job of machinery greaser…
To do it right required inventory, schedules, etc…
I had no idea such a position existed.
In the end it was good I didn’t because a few years later the plant closed and left California…
/ Grease - is there no better way? Can we talk about this? #162
I don’t bother cleaning them to perfection.
... and therein probably lies my problem. I want to be sure they're clean enough that I'm not picking up dirt and injecting it into that or the next fitting.
I would promptly knock it off using the loader or backhoe next to something or in dirt/rock. Seems that every exposed grease fitting is broken quickly.
Yeah, that's why I like the older loader designs so much. The Zerks were always hidden under the loader arms, where they could almost never be damaged. The penalty was that you had to curl the bucket one way and lift the loader arms to grease half of them, and then curl the bucket the other way and lower the loader arms to grease the other half. But every Zerk was exposed and easy to access or clean.
/ Grease - is there no better way? Can we talk about this? #163
Rubber caps will keep the zerks clean…
/ Grease - is there no better way? Can we talk about this? #164
One of the things I hate most about working with equipment is grease. I recently decided I was going to make it easier by getting a battery powered grease gun. Then I opted to put a lube lock fitting nozzle thingy to try to reduce the mess.
It helps but the grease and mess still gets everywhere.
All over my hands. Ruined countless numbers of rags. All over the tractor in places I'd rather not have it. All over the grease gun and even some of my other tools.
Is there a better way? Are there any products I should look into?
Is there no newfangled alternate to grease that isn't quite so messy?
Grease makes the already unpleasant task of maintaining equipment even less pleasant.
Here's what I do, and it's normally after a shower and clean clothes:
step 1 is squirt some out and rub it all over my face, hands, arms, shirt & parts. Then I'm ready to grease the tractors. While I'm at it I grease every zerk in site: mowers, grinding arbor, tools...everything. Then with Gunk, Goop, Go-Jo or any other cleaner starting with a "G" clean Grease best I can off my hands, tools & grease gun wiping with paper towels I burn. Clothes too dirty to wash go to another "G"...the Goodwill.
/ Grease - is there no better way? Can we talk about this? #165
My memory and personal records indicate my Deere 855 manual must have specified a 50 hours schedule for greasing the loader, but I don't have the manual handy to reference anymore (machine sold), and it's possible one of two things happened:
1. Manual was referring to greasing the rest of the zerks on the tractor, but not the loader. I can't even remember if Deere made a separate service manual for their loaders way back in 1986, but I think probably not.
2. Deere assumes that 50 hours on the machine is almost certainly less than 10 hours of loader uppy / downy action.
I did just run out to the barn and pull the manuals for the 3033R tractor and 320R loader, to check their maintenance schedules. The 3033R specifies front axle trunions at 50 hours, and "everything else" at 100 hours. But 320R manual does indeed say 10 hours.
To me, it's all the same. Each 50 hours on the tractor likely yields less than 10 hours of actual loader articulation, based on my usage.
/ Grease - is there no better way? Can we talk about this? #166
In simple terms, I feel every 100 spent on grease will save 1000 of machinery cost later. So I do anything I can do to make it "easier" to grease. I'm not saying to grease too much, just that it's beneficial to remove (perceptions of) obstacles to greasing.
So next to the grease guns I have rolls of blue paper, ready to pull out, and a waiting bin. Leather gloves + nitrile nearby.
The actual grease guns are screw-on manual type (Fuchs in my case). So much less faff than the old type of cartridge, and zero mess when changing cartridges. 2 fresh cartridges are adjacent, and it really takes 10 seconds to replace a cartridge in the gun. Then a G-coupler on the main gun. Another has other fittings for odd zerks.
Minimal mess and no excuses for not greasing!
/ Grease - is there no better way? Can we talk about this? #167
Tried the horizontal storage. The oil that stays in the gun then runs out when you are using it, dripping onto everything beneath. If you happen to be laying under a piece of equipment, guess what's beneath...
Good point. I had not thought of that. I wonder if flipping the gun over every once in a while during horizontal storage would help keep the oil in the grease. In the long run if the oil leaks out, the grease will not be very effective at lubrication. Maybe all grease tubes should have a "best before" date on them.
/ Grease - is there no better way? Can we talk about this? #168
Hi all. I'm both a user and a Schaeffer Lubricants sales rep here in the Hudson Valley,NY. I see some members here are also Schaeffer guys, like to see that. In my excavating biz I have used our 229,238, 274, and my fav, our 219. They're all great aluminum complex greases, all with moly. Little known story most don't know is that during Operation Desert Storm, the tail rotor bearings were going South because of the blowing sand. When that happens, the helicopter gets squirrely and our laser system isn't accurate which could have cost American lives. Our CEO heard about this, called up some mucky muck in our military and told him Schaeffer will donate barells of our 238 grease and there will be no more problems with those bearings. Deal went through and here we are.
I sell at wholesale pricing so if anybody has any questions or wants to order any product, please let me know. Also, want to mention that during August, if you buy a 55 gallon drum of engine or hydraulic oil, you get a free product up to app.a $200 value such as a case of grease, a case of Penetro, Citrol or a fuel additive of some type.
Thanks,
Wayne
914-464-1882
/ Grease - is there no better way? Can we talk about this? #169
Thanks,
Wayne
914-464-1882
I use and am pleased with Texas Refinery 880 Crown and Chassis grease.
/ Grease - is there no better way? Can we talk about this? #170
I can't like that one enough. No comparison and no other grease has ever been used on this farm going back to my Grandfather. One grease every use.
And unlike the cartridge thread. Still metal pull tab and cardboard
/ Grease - is there no better way? Can we talk about this? #171
I’m real unhappy with the Lucas green tubes moving to these plastic pull tabs. Where are you getting it from?
OK, where does one get this in tubes, but lots of them? I have heard this is a great grease, too.
It may be time for a change.
Or I may try the Schaffers.
/ Grease - is there no better way? Can we talk about this? #172
I order by the case direct from them. Was going to be a sales rep but not my thing. 2 cases would get you free shipping. It is by dollar amount. Look for posts by me elsewhere on here I put in the latest price as of 2 year’s ago I believe.
The guy that does some of my hauling uses paragon 2000??? On his forestry mulcher. Similar to 880 but better
I’m fairly certain I have a tweaked universal on my rake pto shaft from an incident over 20 years ago. Is the grease what’s keeping it working this long. Who’s to say.
Had a 30 year old pto yoke wear out on a mower my dad bought new in ‘89. Never had the universal replaced. Is it grease or maintenance? We will never know.
/ Grease - is there no better way? Can we talk about this? #173
I bought by the case from an outfit in Sacramento CA just prior to pandemic.
A case lasts me a very long time.
I wish I could post current 2025 availability.
/ Grease - is there no better way? Can we talk about this? #174
Thanks,
Wayne
914-464-1882
In the Texas oilfield and farm we used to have problems with grease compatibility - at least we thought compatibility was the reason that caused grease to harden. Loader bushing pins locked up by hardened grease were a big problem - we never could figure out why it happened some times and not others.
Of course lots of times we were greasing equipment without knowing what kind of old grease was already in there. We avoided aluminum based greases just because grease tables show they aren't compatible with most other types of grease.
Does any of that apply to Shaeffer's aluminum based grease?
/ Grease - is there no better way? Can we talk about this? #175
/ Grease - is there no better way? Can we talk about this? #176
From the chart, Lithium complex seems the most compatible.
How does one select "Lithium complex" at the grease counter?
Is there an obvious lable on the tube?
I keep one gun just for the water pump on the Fordson. ;-)
/ Grease - is there no better way? Can we talk about this? #177
Not joking chief.
My Kubota maintenance schedule says to grease every 50 hrs so actually i'm ahead of schedule!
Grease will dry out in less than a year.
/ Grease - is there no better way? Can we talk about this? #178
Not in the tube!
THINK!
Grease is no more than OIL in a retentive matrix.
The oil weeps out.. sure!
Moly remains, well sure
But there is little lubricity in the oil retention matrix.
Live with it..Learn the reality!
There is no magic!
OIL is the lubricant, grease is the vehicle!
/ Grease - is there no better way? Can we talk about this? #179
Not joking chief.
You have an MX. How can you say every 50 hours? My MX has a sticker on the loader that says grease every 10 hours.
/ Grease - is there no better way? Can we talk about this? #180
Me too for the Model A water pump..
2019 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A60736)
2019 INTERNATIONAL...
2005 Chevrolet C4500 Altec Bucket Truck (A56858)
2005 Chevrolet...
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
Welcome to the Ranch Metal Decorative Sign (A61569)
Welcome to the...
NEW HOLLAND T4.105F TRACTOR (A62130)
NEW HOLLAND...
2016 FORD F550 CREW CAB SERVICE TRUCK (A59905)
2016 FORD F550...
