The Life of a Custom Mowing contractor
   / The Life of a Custom Mowing contractor #1,601
What air pressure do you run your tires at? I've been thinking that if I lowered my air pressure, I would have a smoother ride. The bouncing from the ground is what wears me out the most when mowing.
I don’t keep real good track of that, but I’d guess mid teens. Like 15 ish.
You can run your tires quite a bit lower than the manufacturer says.
If you run their tire pressure, you’ll probably get youself hemorrhoids or bite your tongue off. lol
   / The Life of a Custom Mowing contractor #1,603
my compact isn’t in the same class Eddie, but after going to Titans website and looking up load vs pressure for my tires I run 12/15 rear/front with mid mount mower and 20/25 with loader/ballast box.
   / The Life of a Custom Mowing contractor #1,604
Do you push stuff like that out of the way with the bale spear? Probably situation dependent??
I like to have the grapple on when I bush hog around my little property for situations just like that.
Oh yeah. My bale spear and frame pushed that branch aside like a toothpick.
I used to always take off the bale spear and put the grapple on when I switched from hay to mowing, but sometimes I just don’t feel like it.
I need to get back to doing that.
   / The Life of a Custom Mowing contractor #1,606
My tractors aren't nearly as big as Hay Dude's. I run 13 psi max in the back tires...I want to see a bit of a bulge in the sidewall. Much easier on me and the tractor and whatever implements I've got hooked up - and better traction also. Same with the front tires - don't remember the exact PSI but I want a little bulge in the sidewall. If I'll be lifting heavy loads with the FEL then I'll add air to the front tires just long enough to do the job.
   / The Life of a Custom Mowing contractor #1,607
Thanks. I'm at 20psi in on my front tires and 15 on my rear tires. I'm thinking of going lower to get a better ride. I'm just not sure how low I can go and not cause any damage?
   / The Life of a Custom Mowing contractor #1,608
I wouldn't go under 12 PSI in the rears, below that working on any kind of side hill your likely to roll the tire off the bead. I like 15 psi in my rears generally to me it seems like a good balance for working and traveling 18.4-30's and then the 20.8-38's. The smaller rears 15-19.5 I keep around 20 psi.
If you go too low, you’ll damage your sidewalls. 20 up front and you’ll be bouncing like a basketball. Are they radial tires? Try backing off a pound or 2 for a while.
I do super heavy loader work ~15lbs no issues, but each tire and tractor will react differently
How about some pond weed wacking? About as fun as getting a prostate exam….
Luckily it was unusually cool only about 70 degrees, so it wasn’t too bad.
UNUSED (1) 3500# DROP AXLE W/ BRAKES (A54756)
UNUSED (1) 3500#...
LONG 2360 TRACTOR (A54756)
LONG 2360 TRACTOR...
2000 FORD F450XL SUPER DUTY SINGLE CAB FLATBED TRK (A51406)
2000 FORD F450XL...
(APPROX 7) 10" I-BEAMS UP TO 12' (A54756)
(APPROX 7) 10"...
More info coming soon! (A53421)
More info coming...
2008 OSHKOSH FRONT DISCHARGE CONCRETE TRUCK (A54313)
2008 OSHKOSH FRONT...
