The Life of a Custom Mowing contractor
   / The Life of a Custom Mowing contractor #1,601
What air pressure do you run your tires at? I've been thinking that if I lowered my air pressure, I would have a smoother ride. The bouncing from the ground is what wears me out the most when mowing.
I don’t keep real good track of that, but I’d guess mid teens. Like 15 ish.
You can run your tires quite a bit lower than the manufacturer says.
If you run their tire pressure, you’ll probably get youself hemorrhoids or bite your tongue off. lol
   / The Life of a Custom Mowing contractor #1,603
my compact isn’t in the same class Eddie, but after going to Titans website and looking up load vs pressure for my tires I run 12/15 rear/front with mid mount mower and 20/25 with loader/ballast box.
   / The Life of a Custom Mowing contractor #1,604
Do you push stuff like that out of the way with the bale spear? Probably situation dependent??
I like to have the grapple on when I bush hog around my little property for situations just like that.
Oh yeah. My bale spear and frame pushed that branch aside like a toothpick.
I used to always take off the bale spear and put the grapple on when I switched from hay to mowing, but sometimes I just don’t feel like it.
I need to get back to doing that.
   / The Life of a Custom Mowing contractor #1,606
My tractors aren't nearly as big as Hay Dude's. I run 13 psi max in the back tires...I want to see a bit of a bulge in the sidewall. Much easier on me and the tractor and whatever implements I've got hooked up - and better traction also. Same with the front tires - don't remember the exact PSI but I want a little bulge in the sidewall. If I'll be lifting heavy loads with the FEL then I'll add air to the front tires just long enough to do the job.
   / The Life of a Custom Mowing contractor #1,607
Thanks. I'm at 20psi in on my front tires and 15 on my rear tires. I'm thinking of going lower to get a better ride. I'm just not sure how low I can go and not cause any damage?
   / The Life of a Custom Mowing contractor #1,608
I wouldn't go under 12 PSI in the rears, below that working on any kind of side hill your likely to roll the tire off the bead. I like 15 psi in my rears generally to me it seems like a good balance for working and traveling 18.4-30's and then the 20.8-38's. The smaller rears 15-19.5 I keep around 20 psi.
If you go too low, you’ll damage your sidewalls. 20 up front and you’ll be bouncing like a basketball. Are they radial tires? Try backing off a pound or 2 for a while.
I do super heavy loader work ~15lbs no issues, but each tire and tractor will react differently
How about some pond weed wacking? About as fun as getting a prostate exam….
Luckily it was unusually cool only about 70 degrees, so it wasn’t too bad.
Livestock Hay Ring - Round Bale Feeder (A55218)
Livestock Hay Ring...
2021 CAN-AM OUTLANDER 650 XMR 4-WHEELER (A51406)
2021 CAN-AM...
2015 AMERITRAIL MANIFOLD TRAILER (A55745)
2015 AMERITRAIL...
UNUSED PROFESSIONAL X2600A ELECTRIC CONCRETE MIXER (A54757)
UNUSED...
CHALLENGER MT525B TRACTOR (A51406)
CHALLENGER MT525B...
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A54757)
UNUSED WOLVERINE...
