Just another junk chainsaw
/ Just another junk chainsaw #2,541
I would like to see good suggestions and examples of the screw drivers used to perform the screw adjustments on chainsaw and string trimmer carbs that don't jump off the screws all the time,
I have not had good results slipping fuel line over the driver shank, Most of the access holes are not big enough.
Isn't a good one made that dont jump off when idling etc. I use 2 different size OEM stihl ones made. IMHO
My echo other day with caps off tuning I noticed the outer on the H had splines too. So tossed the screwdriver and grabbed my spline tool. Easy peasy then.
One on left worked 4mm 21 spline. One in middle OEM husky 5mm. Right Pacman style.
You wrote pulling the one EPA cap left to get more RPMs. I took that to mean you were replacing it. How does that help RPMs?
I took them of the red epa stops off L H. They wouldnt let me get over 10.5K rpms on H side, as thats how they stop you from adjusting.
Ran it fat long enough breaking in.
Took red stops off and got full carb adjustment. Now I am at 12.5k I had it at 12.8K but was super hot and when cools off will change. So went in favor of hair fatter.
I thought about how I was going to run my muffler test on OEM and farmertec clone 2511.
Waiting on one more cnc muffler to arrive.
Then I think I will just run the egan pipe, pss V2, wsc on oem. We all know the oem muffler is a dud stock. So scratch that.
Then run the farmertec clone on it's open small pipe muffler, then egan pipe, pss v2, wsc.
The other guy is going to do it too and also have them put on dyno. egan, pss v2, wsc on the farmertec 2511. Sounding about 3-4 weeks out for him.
pss v2 16.42mm
18.5mm x 7.6mm rectangle. wsc muffler
egan pipe 13.21mm
clone 9.97mm
Common kind echo has used for epa limiter cap.
/ Just another junk chainsaw #2,546
pss v2 16.42mm
egan pipe 13.21mm
clone 9.97mm
Looking forward to your comparison runs. Can you please also post the dyno results when you see them?
When ever that guy does those. He said be 3-4 weeks before he even startsto get to that point.
I'm just doing timed cuts myself and see how each tunes from one to other.
Muffler testing wood picked out for oem and clone.
Pipe, 2 cnc mufflers from different makers and the open clone.
Going to use Oregon nano 325 set ups on oem 2511 PN and clone Farmertec G2511
This vmodest 2511 just used to check it.
1/4” mini fruit tree pruner saw.
9x8 and it's 9 down.
Walbro carbs on the Farmertec China clone saws
I always figured they were made at the China walbro plant.
Dealer contacted Walbro = We have contacted walbro and verified in fact that the carburetors are made by walbro. By a marking on the carb they could tell me what plant they where made in. The 660 and 372 carbs are made in Thailand for the china market. So I would assume the rest are made in the Thailand walbro factory.
Dealer = Just pulled the walbro carb off the new g366 pro and it has the same markings indicating it is made also in the Thailand plant.
Carb pic with marking
/ Just another junk chainsaw #2,551
Can you even imagine the mind numbing experience of building those things all day, every day and having them sold for less than $20 on the internet market?
24 is Farmertec price then 10 shipping for total 34 for slow mo.
They are little more by dealers in US.
372 one like on the G372xp pro I show.
My stihl 460 cylinder was only 15 I put on this year.
@CalG another US dealer I know. 64 shipped. For 372 one.
Gangs all in hand now. To test on oem and clone 2511’s.
PSS V2 cnc muffler has 33% bigger exhaust outlet.
/ Just another junk chainsaw #2,555
The second saw I grew up with, after the Mini Mac, was a Homelite XL12, Straight pipe (well basically just a vented tin box. Your ears thumped, it was Deafening. No wonder I am hard of hearing today.
1/2 cord you were deaf and numb for the rest of the day.
I had a Mac 555 that would make my ears bleed. Guy a worked with had bought it new.
Wish I would have took a pic of the deal it used for so called muffler. it's pitch hurt. :ROFLMAO:
Sold to local collector for 75.
Begged him to take the like new mini mac and yellow case for 20 too. 😂
These pipe deals on these 2511 25cc saws not to loud at all IMHO. I figure the straight through open muffler ones will be even quieter.
Dyno even shows proven gains with the design. So they knew back then using those open pipe muffler design deals.
I think I got a pic of one on my old poulan top handle I sold.
/ Just another junk chainsaw #2,559
That was the Muffler on the XL12 Nothing "Tuned' about it, just Loud.
/ Just another junk chainsaw #2,560
2020 Water-Land Dba Continental Trailers Trailer, VIN # 1ZJBU1415LC037150 (A61569)
2020 Water-Land...
PALLET OF DOORS, SCREEN DOORS, ESC (A63291)
PALLET OF DOORS...
2025 HT360W Mini Walk-Behind Track Loader Skid Steer (A61572)
2025 HT360W Mini...
2017 Caterpillar 349FL Hydraulic Excavator (A61572)
2017 Caterpillar...
NEW HOLLAND TS115A TRACTOR (A62130)
NEW HOLLAND TS115A...
(50) UNUSED 3'x8' CORRUGATED METAL SHEETS (A64281)
(50) UNUSED 3'x8'...
