How agriculture works thread
/ How agriculture works thread #1,012
Round Bales fundamentally changed how the dairy farms processed hay for my grandfather/uncle.
For centuries the loose hay was stored in the hay loft…
With round bales the need for haylofts faded as wrapped bales were field stored.
/ How agriculture works thread #1,013
Plus, you could put up more hay in a day than most old-timers ever dreamed of.
/ How agriculture works thread #1,014
That would depend a lot on the climate and ground moisture of your area. Around here the old Alis Chalmers small rounds had to be put in the haymows. Otherwise just like the large rounds of today the waste was tremendous when stored on the ground.
I forget the actual percentage of waste is with the big rounds but even just 6" of garbage hay from mold and rot is a large percentage of a 5' round bale.
There are people that will stack net wrapped round bales outside and swear the waste isn't that much, they haven't put a sharp pencil to those numbers, that said those drier climates with less ground moisture and rain can get away with it for beef animals but the percentage of waste is still quite large.
/ How agriculture works thread #1,015
Grandfathers farm went from loose to round with no square bales in between..,
/ How agriculture works thread #1,017
Steyr which is part of Case IH, New Holland, and Case
Steyr founded in 1864 was part of Daimler and also renown firearm manufacturer.
Tractor is 1948 diesel nominal 12hp crank start.
I remember cold winter starting required a glow plug lit with a match and then screwed into the cylinder head just before cranking…
The hay wagon was retired when this arrived…
No more manual labor loading and unloading the hay wagon.
/ How agriculture works thread #1,018
Starting with match lit glow plug and crank
1,100 hp Big Bud 16V-747 tractor at work in the field with @titangoodyearfarmtires LSW 1400 tires with an interview with Ron Harmon the owner of Big Bud Tractors and the Williams Brothers who farm with it.
Volvo ECR235CL (A53317)
Volvo ECR235CL...
Ford Pickup Truck Bed (A59230)
Ford Pickup Truck...
2015 JOHN DEERE 1050K WH CRAWLER DOZER (A52707)
2015 JOHN DEERE...
Zero Turn Mower (A59231)
Zero Turn Mower...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
PREVIEW DATES AND TIMES (A61165)
PREVIEW DATES AND...
