TYM - T474HC My next work partner.
/ TYM - T474HC My next work partner. #22
Decided I wanted to get back into a HST transmission Tractor. Went with a new TYM T474 HC…..View attachment 3539959
Had the dealer load the rear tires, add a plug-in block heater, and the 3rd function kit down the loader. Should make for a comfortable, year round work horse.
Who else has one of these or the 494/574?
I bought a 474 in June as well. Currently shopping for oils for my 50hr change. Having trouble finding a hydraulic oil i like locally. Bought the full filter kit from my dealer and found the same kit online for half the price from dealer in Colorado. Shop around before you buy
/ TYM - T474HC My next work partner. #23
The TSC Traveller Premium Tractor fluid works in my 574H (same engine as the 474, but turbo).
/ TYM - T474HC My next work partner. #25
I have a 2024 474 w/ cab. 138 hours. No regen thus far. Only issue I've had was a the valve that opens for heat/AC failed and the dealer replaced it. It was dripping red fluid from above the cab onto the floor steering wheel and floor .Said very unusual repair. The heat works well and so does the AC. I'm considering wheel spacers to widen the rear stance 3" on each wheel for more stability. Otherwise a lot of tractor for $$$$.
/ TYM - T474HC My next work partner. #26
Get Brotek spacers, they are the best bang for the $$$, I put 1.5 spacers mostly to make room for chains in the winter. But added 3'' overall.
/ TYM - T474HC My next work partner. #27
Thanks for the heads up on the valve leak. Will watch for it. Spacers will probably affect warranty and will put more load on bearings.
/ TYM - T474HC My next work partner. #28
So far I've not heard of that, and VERY few tractors have hub problems on the rear.
/ TYM - T474HC My next work partner. #30
Some days I wish I had gone a little bigger. Some days I miss having a backhoe. But it’s mowing well and doing light duty loader work well. So far, so good.
I considered a backhoe, but iirc, it was an additional $7k-11k. That's a lot of mini-ex rentals.
/ TYM - T474HC My next work partner. #31
I’ve had my T474 a couple of months now. It is used for logging. I don’t know if there is anything more demanding on a tractor - moving heavy logs, pulling stumps, running a chipper. I’ve learned I need to be easier with it than I was on the John Deere. I’ve already bent the loader mounts, but they have been replaced with new ones and reinforced.
/ TYM - T474HC My next work partner. #32
What JD model did you compare it to?
Problems with my TYM. Here we go again. TYM474HC has less than 50 hours on it and it’s in the shop. Keeps losing RPMs to the point of almost stalling. Took it to the closest TYM dealer and asked them to do the 50 hour service and find out what is going on with it.(47 hours) They completed the 50 hour service and I think it was $390ish dollars. No problem. Thanks for doing it. They thought they knew what the problem was and showed me how the hydraulic filter’s insides had collapsed. What? Said they never seen it before. Must of been a defect from factory. Me either. Never seen that before. But everything worked fine now when they drove it. Brought it home and found time to use it the next day or two. Did a little moving of sticks and stones in the bucket and after 10-12 minutes I started to do some back dragging to level the area off. RPMs dropped to almost nothing again and kept doing it. I had to drive it back slowly to the barn. Called them up and they said okay we will come and pick it up. It’s been two weeks tomorrow. They are a busy place. I get it. They told me last Saturday that they thought they would get it in Monday and have it back to me Monday or Tuesday afternoon. It’s now Friday. Frustrating. To say the least. Just dam depressing, souring my mood toward everything. I have literally mowed grass with it, moved a few buckets of dirt, rocks, sticks, and turned the horse manure pile several times. About 47 hours on it. No response when I call them. Get answering machine and it says to leave a text. Did that. No response. Just lost on what to do. Wait. I guess.
I guess I should have spent the extra $20,000 and bought a new Kubota. Or better yet. Bought a used Kubota about the same price. Never had any problems with the Kubotas. :cautious:
/ TYM - T474HC My next work partner. #36
If its not a long haul to the dealership maybe stop in to speak with someone. I will say that depending on what all they sell and service, september and October is usually busy season for outdoor power. Hopefully they prioritize warranty repairs though...
One hour and ten minutes to dealer. Closest one. Hate to drive down there to find we haven’t figured it out yet. Or had to order parts and waiting on them. I would think they would at least get ahold of me and keep me apprised after they couldn’t get it back to me on Monday or Tuesday afternoon like they said. Give me some information. I called during business hours and their answering machine says they are with other customers. And to send a text to this number…….. I followed the directions and they don’t even respond to me. The owner seems like a great guy. I don’t get it. I don’t depend on my tractor for income. But what if I did? And that shouldn’t matter. It’s nearly new. 😖
/ TYM - T474HC My next work partner. #38
That blows. Odd as that engine doesn't have a derate built into the ECM as far as I know. This is just simple mechanical injection. So, it isn't a limp mode or sensor. Fuel?
It would be nice to know what they have tried and not tried. I can’t get a response from them. This is a smaller dealership, compared to the big ones, but they sell a good amount of TYM tractors. Have techs who contact TYM tech support for troubleshooting, etc. Owner seems like a great guy. I just can’t believe it. With this low of hours.
/ TYM - T474HC My next work partner. #40
I've got the same hours on my Branson 4820H, no hiccups thus far. Only used the dealer for filters.
2012 Kenworth T800 T/A Sleeper Cab Truck Tractor (A60352)
2012 Kenworth T800...
2019 CATERPILLAR  XQ35 GENERATOR (A58214)
2019 CATERPILLAR...
TAYLOR POWER SYSTEMS SKIDDED GENERATOR (A60736)
TAYLOR POWER...
2006 GMC C5500 4X2 BUCKET TRUCK (A59906)
2006 GMC C5500 4X2...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2016 American Eagle S/A Self Loading Reel Trailer (A60352)
2016 American...
