Kubota L3400
/ Kubota L3400 #1
creditdoc35
l3400
I am looking at getting a L3400. Its a 2007 with no front end loader. it has under 500 hours. my biggest concern it that it doesnt have the loader. it has 4 attachemnets finish mower, tiller, brush hog,and plow. Are they hard to get?
/ Kubota L3400 #2
Welcome to TBN.
L3400 in past been known for jerky hyd,also fuel sometimes work.
/ Kubota L3400 #3
I know nothing about the model other than a loader was an option. You may be able to locate one at a tractor wrecking yard for that model at a reasonable price. If not there are after market manufacturers. I have had a loader by Koyker which was really nice but there are others such as Woods. Figure on paying probably $6000 for a new after market loader and the hassle of installing it. TractorData.com Kubota L3400 tractor information
/ Kubota L3400 #4
I have a L3700 SU which is basically the same tractor. It comes with a 463 loader and I have seen a few for sale on CL and marketplace over the years. The 3PH is jerky when trying to feather it.. I wish it wasn't . Overall the tractor is very solid and well built. No electronic or DPF BS to worry about. I bought mine new..Have about 400 hours on it now and has been trouble free outside of some self inflicted wounds.
/ Kubota L3400 #5
Pretty sure the frame is still the same and the newer LA524, 525, and LA 526 should still work with the L3400. If not there are a coouple of after market ones that should fit (and lift more).
By 2007, the real bad Jerky hitch should have been taken care of... problem is if this tractor sat on a dealer's lot for a year or more, it could actually be 2006. It's not a problem but it's less desirable.
There are great tractors... is it 4x4? Gear or HST?? Price?
/ Kubota L3400 #6
My L3700 is something like a 2012 and still has the jerky 3ph.
/ Kubota L3400 #7
Do yourself a favor and stop looking at this one. It would be different if you Didn’t want a loader.
Find a complete tractor w a loader.
/ Kubota L3400 #8
I had an L3200 and it was a good tractor. The 3PH didn't operate smoothly, but it wasn't a handicap with the RFM, blade, landscape rake, etc that I used. I'd pass as arrow suggests. You'd really need some luck finding a loader (and getting it installed).
/ Kubota L3400 #9
Welcome to TBN.
I have a L3400, bought new in 2009. True, the 3pt is sometimes a little 'jerky'. But, that really hasn't been a major complaint on my part, i.e. no big deal. I have no knowlege about the 'fuel problem' mentioned, as I've never had one with my L3400. No complaints at all with mine, FWIW.
/ Kubota L3400 #13
Does anyone know which kubotas had the quarter inching 3pt as opposed to position control?
/ Kubota L3400 #15
I used my 2004 L3430 for 10 years and 1K hours before trading up. It was a great tractor and I got every penny it cost new, back in trade. Yeah, the 3pt was a bit of a pain, but I got used to it. No fuel system issues though.
That L3400 looks like a good deal, but as others have said, if you really need a tractor with a loader, it will likely cost more to add one than buying a tractor with a FEL already attached.
Do you need the four implements that come with the L3400? If not, you could sell the ones you don't need to offset the cost of adding a loader.
How much work do you do that requires a FEL? They are certainly handy for a variety of day to day tasks, but if you could rent a tractor with FEL to do occasional loader work, that L3400 would be a good choice.
Just my 2 cents.
/ Kubota L3400 #16
Try Westendorf Manufacturing for an FFL, I purchased one for an old L4200 I purchased a few years back, it included all mounting brackets, hoses, etc.
/ Kubota L3400 #18
My B2620 had quarter inching, the BXxx80 series does also. The Bxx01 that replaced the Bxx20 series has position control. The Bxx30 series, which was replaced by the LX series, had position control also. Except I believe there was a B or LX series SU model that didn't(I just looked it up, it was the B3350su that was quarter inching) . It gets confusing.
I think the only models that don't have position control now are the BX
/ Kubota L3400 #19
I bought my first tractor new, without a loader. When time came that I needed a loader, I bought a Woods and had it installed. It was close to $6k at that time, but it was a great loader and lifted a lot. I was very happy with doing that.
/ Kubota L3400 #20
PORTA POTTY (A68842)
2012 MERTZ FRAC MANIFOLD TRAILER (A67714)
2012 MERTZ FRAC...
2000 Belshe dt-255 Trailer (A64194)
2000 Belshe dt-255...
1990 FORD LT9000 HOT OIL TANK TRUCK (A67714)
1990 FORD LT9000...
2012 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A67714)
2012 DRAGON 150...
213063 (A64276)
213063 (A64276)
