Good morning!!!!
   / Good morning!!!! #209,133
Hot and humid, but a nice breeze...just got back from a hike and swim for Della.
Hope you had a great birthday, Kyle...you deserve the best.
Finally cleaned the zero yesterday, scraped the underside of the deck, and swapped out the 3 blades with the ones I sharpened. I just had to try it out and mowed for an hour. I should have weighed the gunk pile I scraped out...lifting up the tarp it was on was a job...grass has been so damp, it really accumulated.
   / Good morning!!!! #209,134
66F steady rain heavy at times with gusty winds ending around 5:30pm.
Been slow putter day still little sore from yesterday work out.
Tomorrow I'll start looking for part time job that will fit my hours and interest...I'm getting bored :( Mrs. gave me :rolleyes: look.
Plans for the evening next to nothing.
Enjoy your evening all.
   / Good morning!!!! #209,135
Good Afternoon,
The critter was not a ground hog but a skunk 😳
But I think he is out of the barn, at least I hope he is because we will be leaving tomorrow and he won’t survive 2 weeks with no water 😉
Ponytug, yes Riptides Mike is MIA, I need to send him a PM ! 🥲
He might be tied up with work ?
Hope all had a good worship today and enjoyed another day on planet earth 🙏
   / Good morning!!!! #209,136
Sounds like we both had the same results.
I use Mrs. hand metal flower trowel for scaping etc. does nice clean job (y) need to clean under deck more often tho.
   / Good morning!!!! #209,138
Popgadget, do you program your smaller holes a little oversize or use cutter comp, or slow your feed down?
I use Fusion 360 to generate the G code, I select optimization, which lets me slow the feed rate by whatever factor I choose. It was 50% and only inside curves. It also does the compensation for the kerf that I specify.
It took some tweaking to get it accurate.
   / Good morning!!!! #209,139
But Paul suggested a much better way, cut off the oem connector and solder it on the new speaker. Which we did.
   / Good morning!!!! #209,140
Good Evening Thomas,
You must be little anxious getting back to radio interest with new ideas Scotty.
Yes Thomas, I have been kind of over the top with ordering new radio equipment much to the chagrin of my lovely wife Kathleen! 😉 Smd I just ordered a bunch of new equipment for operating portable out in the parks. I think it’s about time to start saving money next month considering I’ve spent well in excess of $$3500 or more ! 😳 But when your having fun ??? 😉 I just feel if I can break my butt hauling oil hose,if I want to have some fun occasionally I should do it considering i probably only have a handful of years left ! JMO ! 🙏
Ammco Brake Machine (A55758)
Ammco Brake...
1667 (A57192)
1667 (A57192)
2015 Ford E-350 Cutaway Van (A55973)
2015 Ford E-350...
2011 Ford F-150 Ext. Cab Pickup Truck (A55973)
2011 Ford F-150...
2000 Nabors 40 Ton T/A Flatbed Equipment Trailer (A55973)
2000 Nabors 40 Ton...
2008 Ford F-250 Service Truck (A56858)
2008 Ford F-250...
