Solving the “Floppy Bucket” by adding a flow restriction
/ Solving the “Floppy Bucket” by adding a flow restriction #1
shooterdon
Super Member
Near Johannesburg MI but in the middle of nowhere
2019 LS XR4140 HST Cab; 2025 Moto UForce 1000; 2021 Bad Boy 54" ZT Elite
Has anyone added a flow restrictor valve to cure this problem?
Would you recommend the valve you used and was one needed on each bucket curl cylinder?
Thanks.
/ Solving the “Floppy Bucket” by adding a flow restriction #2
/ Solving the “Floppy Bucket” by adding a flow restriction #3
That is correct, you only need one on the hose from the valve, and it does help floppy bucket syndrome. The one recommended above is good because it is adjustable so you can dial in the amount of restriction you need, instead of having a fixed non-adjustable orifice, and is one way so it does not affect flow in the other direction. Changing the hydraulic filter regularly and running at full throttle helps also so you will have maximum hydraulic flow. The problem is caused by cavitation in the bucket cylinders when hydraulic flow does not keep up with demand when dumping the bucket. The restrictor prevents dumping too fast so that it does not cavitate.
/ Solving the “Floppy Bucket” by adding a flow restriction #4
The floppy bucket syndrome is not much an issue with my xr3140, but the deere 790 is very prone to it. Over the time of 18 years of operating the deere loader I did find dumping slowly helped very much on the flop bucket and nothing happens syndrome when the lever is pushed to curl back up....
/ Solving the “Floppy Bucket” by adding a flow restriction #5
Excellent post GS650GL !! I was able to remove my one way restrictor after a while and found the bucket curl functioned as normal. I’ve seen many of these safety issues on brand new tractors. Dealers should be required by law bleed the air out as part of the pre-sale assembly procedure. This can be very dangerous when someone is new to tractors and puts a set of forks on it and they drop like a rock with a load on them. Very dangerous. Serious safety issue for dealers and manufacturers. Great post !!
/ Solving the “Floppy Bucket” by adding a flow restriction #6
Apparently the new MT2 series such as a MT242 now have a different loader control valve with an oil regeneration circuit that helps to fill the cylinders faster during the dump cycle to reduce floppy bucket syndrome. Just heard about this from my dealer's LS service rep. He also said the hitch control valve is different too, so the hitch won't be so jerky when trying to raise slowly or making small height adjustments.
/ Solving the “Floppy Bucket” by adding a flow restriction #7
This is good information to know. Happy to see they recognize there is an underlying defect in the products they sell. For the money they charge for the tractors, this is known issue and there should be a recall on all machines for correction.
/ Solving the “Floppy Bucket” by adding a flow restriction #8
All brands of tractors can and do have floppy bucket syndrome, not because of a defect but because of the laws of physics. During the dump cycle, the weight in the bucket pulls it down faster than oil can be supplied to fill the base end of the cylinders which causes cavitation. While oil is emptying from the rod end of the cylinders which holds less oil, it takes longer to fill the base end which holds more oil. The rod end holds less oil because the rod takes up space inside the cylinder. A cylinder always retracts faster than it extends for this reason, and also has more power extending than retracting because the piston has less surface area where the rod is attached to it. If you apply equal pressure to both ends of a cylinder at the same time, it will extend because of the difference in piston surface area. Normally during the bucket dump cycle, the oil emptying from the rod end returns back to tank. But the oil regeneration feature instead adds the oil emptying from the rod end to the oil being supplied from the valve to the base end. The combined flow helps to prevent cavitation. Sorry, but no manufacturers will have recalls on the units they made previously without oil regeneration. Maybe someday all brands may have it to keep up with the competition.
/ Solving the “Floppy Bucket” by adding a flow restriction #9
There is always the possibility of adding a regenerative valve to the circuit.
/ Solving the “Floppy Bucket” by adding a flow restriction #10
It's nice when a manufacturer works to make solid improvements and not just cosmetic changes.
UNUSED WOLVERINE 3PT QUICK HITCH (A64281)
UNUSED WOLVERINE...
2017 International HX620 Quint Dump (A62613)
2017 International...
1987 International 1954 Elliott ECE 3-65H Telescopic Boom Lift Truck (A61573)
1987 International...
2022 EZ-GO ELITE...
2014 Tennant ATLV 4300 All-Terrain Litter Vacuum (A61572)
2014 Tennant ATLV...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
