Kubota L3301 won't throttle down
   / Kubota L3301 won't throttle down #1
Mr Natural
Alabama
Kubota 3301 and early 60's MF
The tractor has about 375 hours on it and never had a problem till this. It will throttle up, so I don't think it's the cable, but won't idle down past about 2000 rpm. No regen icon flashing.
What do you suppose is up with that ?
   / Kubota L3301 won't throttle down #3
If it's a manual cable vs electronic, even at those hours it can be a gummed up cable. Mine had many more hours, but it happened once.
   / Kubota L3301 won't throttle down #4
If it ends up not being the cable or linkage, perhaps it's related to the higher rpms required for regeneration. I know the Regen lights are not on, but perhaps the computer is calling for 2000 rpm for a Regen? After ruling out cables, I think I would disconnect the battery for 5 minutes or so and see what happens.
Some Kubota dashes also report error codes after pressing a sequence of buttons.
good idea. I will try that.
   / Kubota L3301 won't throttle down #6
Sounds like a call to the dealer to diagnose and fix the issue. Again, every time I read these posts, I'm sure glad neith of mine have any emissions junk on them.
You coudn't give me any T4 tractor.
Yeah. My old early 60's MF was sometimes a pita but I could always get it running.
It may not be that but I was wary of the regeneration process when I bought it. Just another something to go wrong. And computers too. There is a lot to be said for keeping it simple.
images
   / Kubota L3301 won't throttle down #9
What year is it? If I recall correctly they have a 5 year warranty.
TORO GREENS MOWER (A56857)
TORO GREENS MOWER...
2014 Lincoln MKS Sedan (A59231)
2014 Lincoln MKS...
2019 Ford F-150XL (A60462)
2019 Ford F-150XL...
2020 CATERPILLAR 306 CR EXCAVATOR (A60429)
2020 CATERPILLAR...
2013 Chevrolet Van (A55973)
2013 Chevrolet Van...
Bush Hog 72in Rotary Brush Cutter Tractor Attachment (A55852)
Bush Hog 72in...
