Kubota L3301 won't throttle down
   / Kubota L3301 won't throttle down #1
Mr Natural
Alabama
Kubota 3301 and early 60's MF
The tractor has about 375 hours on it and never had a problem till this. It will throttle up, so I don't think it's the cable, but won't idle down past about 2000 rpm. No regen icon flashing.
What do you suppose is up with that ?
   / Kubota L3301 won't throttle down #3
If it's a manual cable vs electronic, even at those hours it can be a gummed up cable. Mine had many more hours, but it happened once.
   / Kubota L3301 won't throttle down #4
If it ends up not being the cable or linkage, perhaps it's related to the higher rpms required for regeneration. I know the Regen lights are not on, but perhaps the computer is calling for 2000 rpm for a Regen? After ruling out cables, I think I would disconnect the battery for 5 minutes or so and see what happens.
Some Kubota dashes also report error codes after pressing a sequence of buttons.
good idea. I will try that.
   / Kubota L3301 won't throttle down #6
Sounds like a call to the dealer to diagnose and fix the issue. Again, every time I read these posts, I'm sure glad neith of mine have any emissions junk on them.
You coudn't give me any T4 tractor.
Yeah. My old early 60's MF was sometimes a pita but I could always get it running.
It may not be that but I was wary of the regeneration process when I bought it. Just another something to go wrong. And computers too. There is a lot to be said for keeping it simple.
images
   / Kubota L3301 won't throttle down #9
What year is it? If I recall correctly they have a 5 year warranty.
2231 (A58376)
2231 (A58376)
2008 Kenworth T800 Semi Tractor, VIN: 1NKDX4TX68R235070, Day Cab, Cummins ISX-600 Turbo Diesel (A59076)
2008 Kenworth T800...
2019 Chevrolet Silverado 1500 Pickup Truck (A55973)
2019 Chevrolet...
Portable Gantry Crane w/ 5 Ton Chain Hoist, 9' W x 12'H (A59076)
Portable Gantry...
2025 YOUERT YOU12 1-Ton Mini-Excavator with dozer blade (New/Unused) (A59225)
2025 YOUERT YOU12...
SDLanch SDLD25 Rubber Track Dumper (A57149)
SDLanch SDLD25...
