1025r 54d autoconnect lift issue
/ 1025r 54d autoconnect lift issue #1
Fpf
Kubota bx2230
I just purchased a 2022 1025r with a 54d autoconnect. With 3pt lever all down, know in connnect position. The deck connects. Moving the 3pt lever to raise the deck, it only moves up 1/2" - 3/4".
With mower removed, 3pt lift in the most upper position. The lift arms for the mower have about 2" -2 1/2" of play before they hit the tractor chassis. There appears to be a slide adjustment inside the rear tire on the left side. It is all the way to one end of the adjustment.
I took a picture but I'm have problems adding to this post.
Thank,
Francis
Thank,
Francis
So, after doing a little research I decided to try some adjustments. Removed the left rear tire and adjusted the slide bar so there is no gap on right side. Then I adjusted (shorten) the two couples that lift the deck. Now the is about an 1"-1 1/2" clearance on the mowers front skid plate.
How much clearance should there be on front skid plate whe the mower is raised?
Thanks,
Francis
2020 Chevrolet Silverado 1500 Pickup Truck (A59230)
2020 Chevrolet...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2016 FREIGHTLINER...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
2016 John Deere 35G Mini Excavator (A55973)
2016 John Deere...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
UNUSED KJ K4230G-42' X 30' METAL STORAGE SHED (A60432)
UNUSED KJ...
