1025r 54d autoconnect lift issue
   / 1025r 54d autoconnect lift issue #1
Fpf
Kubota bx2230
I just purchased a 2022 1025r with a 54d autoconnect. With 3pt lever all down, know in connnect position. The deck connects. Moving the 3pt lever to raise the deck, it only moves up 1/2" - 3/4".
With mower removed, 3pt lift in the most upper position. The lift arms for the mower have about 2" -2 1/2" of play before they hit the tractor chassis. There appears to be a slide adjustment inside the rear tire on the left side. It is all the way to one end of the adjustment.
I took a picture but I'm have problems adding to this post.
Thank,
Francis
Thank,
Francis
So, after doing a little research I decided to try some adjustments. Removed the left rear tire and adjusted the slide bar so there is no gap on right side. Then I adjusted (shorten) the two couples that lift the deck. Now the is about an 1"-1 1/2" clearance on the mowers front skid plate.
How much clearance should there be on front skid plate whe the mower is raised?
Thanks,
Francis
2015 Ford Fusion Hybrid Sedan (A56859)
2015 Ford Fusion...
towable floodlights (A56857)
towable...
10,000lb. forklift skytrack (A56857)
10,000lb. forklift...
2009 International 7400 Altec A77-TE93 92ft. Material Handling Bucket Truck (A55973)
2009 International...
2017 FORD F350 CREW CAB 4X4 PICKUP TRUCK (A56138)
2017 FORD F350...
JOHN DEERE 330G SKID LOADER (A58214)
JOHN DEERE 330G...
