1025r 54d autoconnect lift issue
   / 1025r 54d autoconnect lift issue #1
Fpf
Kubota bx2230
I just purchased a 2022 1025r with a 54d autoconnect. With 3pt lever all down, know in connnect position. The deck connects. Moving the 3pt lever to raise the deck, it only moves up 1/2" - 3/4".
With mower removed, 3pt lift in the most upper position. The lift arms for the mower have about 2" -2 1/2" of play before they hit the tractor chassis. There appears to be a slide adjustment inside the rear tire on the left side. It is all the way to one end of the adjustment.
I took a picture but I'm have problems adding to this post.
Thank,
Francis
Thank,
Francis
So, after doing a little research I decided to try some adjustments. Removed the left rear tire and adjusted the slide bar so there is no gap on right side. Then I adjusted (shorten) the two couples that lift the deck. Now the is about an 1"-1 1/2" clearance on the mowers front skid plate.
How much clearance should there be on front skid plate whe the mower is raised?
Thanks,
Francis
12V Diesel Fuel Transfer Pump (New/Unused) (A59225)
12V Diesel Fuel...
(3) ALUMINUM STEP LADDERS (A58374)
(3) ALUMINUM STEP...
2015 Freightliner M2 106 AWD Versalift TMD2047T Insulated Digger Derrick Truck (A55973)
2015 Freightliner...
2008 MACK CHU613 DAYCAB (INOPERABLE) (A58214)
2008 MACK CHU613...
Automatic Tire Changer (New/Unused) (A59225)
Automatic Tire...
2017 Snorkel S4732 Scissor Lift (A57453)
2017 Snorkel S4732...
