jwmorris
- Joined
- Oct 3, 2007
- Messages
- 1,199
Vevor does as well and is very cheap. The one I have is holding up well and in use on a stump grinder.
This is super helpful. My shafts are much shorter so they don’t vibrate as wildly but it’s totally possible that they were misaligned and I didn’t even know.
Yep. Before the standards, you had good and bad options. Standardization is typically good, but sometimes the 'standard' chosen isn't even the best choice available at thst point in history.Somebody said standard began in 1980. I have equipment older than that (New Holland) and shafts are rectangular. The old baler I recently sold and the ancient Haybine I still for the few acres of hay I cut are rectangular. I realize the OP's cutter is really old but I can't remember one that can be put together out of phase. My recommendation on this is buy an entirely new driveline.
A lot of drive lines look square but aren't, check the measurements of the shaft. They are made that way so that they can't be assembled out-of-phase. Possibly yours had a damaged yoke at one time and somebody put a replacement yoke on it out-of-phase. Hard to do, but with a good grinder and welder, anything is possible.Thank you. This is good news then. I also found that one of the yokes is now missing the cap and bearings, so that is part of the problem in combination of the misphasing. I’ll get yoke corrected this week assuming supply has the right parts in stock. I should be able to correct the alignment by just rotating the shaft since it is square. Thank you for your help.
That's right, and most shafts that look square probably aren't, they may be 1" by 1 1/8", so that they cannot be assembled out-of-phase. If somebody modified a shaft or yoke to make it work, that could be part of the vibration problem and if you need to replace the shaft or yoke, most good machine shops will have the correct dimensioned shaft stock or yokes to make it right.Kodiak45, while you have it apart, straighten out the metal cover, your ears will appreciate the effort.
Naw, surely not I'm the only one to forget to disconnect the pto shaft from the tractor when unhooking.
This is the first I've heard of pto shaft timing, but then all my stuff is 540RPM. My triangular shafts have 1 longer side.
You could have included the rest of the 'pup' in the picture as well....I just bought a 55" collapsed length 540 tractor end 21 spline baler end, CV jointed + slip clutch for $600 from this place. It weighs about 100 lbs. For my Vicon 1210 round baler. The guy who sold it had removed the CV shaft and replaced it with a standard one apparently to keep the value of it. Turning in the field was a nightmare.
CV joint equipped shafts are usually 2 - 3 times the price of a plain vanilla one.
We love ALL pups here, including our Aussies. Never met a pup we didn't like. Candidly, I prefer pups over people most times...
Although I disapprove of my doggos being anywhere near my machinery, here is the rest of the pack:You could have included the rest of the 'pup' in the picture as well....
I'm under the impression that distance should be 14" for a 540 rpm and 16" for a 1,000rpm shaft.I'll agree with the other suggesting a new shaft for the front one.
Also your drawbar is set to short, your drawbar hitch pin should be very close to midway in the shaft. That allows equal angles in the shaft.Most tractors the drawbar can be adjusted in or out.
The 14 inches from the end of the PTO shaft to the center of the hole is standard for a 540 rpm PTO (16 inches for 1000 rpm PTO). This ensures the pivot point for the u-joint on the PTO driveline is the same as the pivot point on the drawbar and reduces the stress on the u-jointI'm under the impression that distance should be 14" for a 540 rpm and 16" for a 1,000rpm shaft.
That is per maiuk in 2010.
So this thread is going to the dogs!Although I disapprove of my doggos being anywhere near my machinery, here is the rest of the pack:
Called my dogs over to see what they would do and they just went back, laid down and went to sleep!So this thread is going to the dogs!![]()
