Remove pto shaft
/ Remove pto shaft #1
Murphys Law Farmer
JD4100, NHTN75
Well I broke my PTO shaft on my Gehl 2170 haybine. I’m going to have to repair/replace the tractor coupler end.
But my problem is getting the old piece off my tractor! The coupler slides forward and back on the PTO shaft, but can’t get past the detant to remove it. The release is usually to pull back on the collar. That is no longer spring loaded. I couldn’t pull the collar back by hand but used an L pry bar. The collar stays back. But doesn’t seem to have pulled the rollers/balls out of the way.
So, do I just order a mini grinder and start hacking away? So much for the cut hay laying in the field. Should have followed my father’s advice—“Never start a plumbing project on a Sunday or Holiday”. But that was my weather window.
/ Remove pto shaft #2
Hook a 1" ratchet strap on the collar or yoke on the tractor end and get some tension on it and then start tapping the tube with a ball-peen or similar hammer. I have one that hangs up and the ball bearings don't retract all the way around. With a little (or lot) of tension and patient tapping it always pops off. Spray lube or penetrating oil will help the process.
/ Remove pto shaft #3
Also, how did you "break the PTO shaft"? Just snapped it or bent it or what?
/ Remove pto shaft
A combination of turning too sharp, on a hill, with ruts in the field.
/ Remove pto shaft
I cut the collar off the coupler. Both bearings are visible. They roll easily as I slide the coupler in/out on the tractor’s shaft. At no point do they sink in or move out farther. But I still hit a dead stop trying to remove the coupler from the shaft. Ideas?
/ Remove pto shaft
Groan. I see it now. I’ve buggered the splines on the end of the tractor’s PTO shaft. It now has a lip. Guess I’ll try grinding/filing them out.
SDLGC100 Golf Cart (A64047)
SDLGC100 Golf Cart...
12ft S/A Utility Trailer (A61574)
12ft S/A Utility...
BOBCAT 3650 UTV (A63569)
BOBCAT 3650 UTV...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A DAY CAB TRUCK TRACTOR (A59908)
2017 FREIGHTLINER...
2011 John Deere 5085 70HP Utility Tractor (A60352)
2011 John Deere...
Unverferth 235 Seed Tender Wagon (A64047)
Unverferth 235...
