I finished a big project (installed a new septic tank)and as rewards, I got my wife a new frig and got a Carry All. I hope to take measurements off of it soon so I can pick up some steel to reinforce it.
Carry
Yes, she does sag a little when heavily loaded. That bracing would definitely help.That looks like it puts a lot of force on the welds at the joints between the uprights and the lower arms. Here's what mine looks like:
I found this simple deck has worked well for me.
If you plan on modifying to exceed design limits, be sure to beef up the area around the 3pt lift pins.Thanks everyone for the replies and the ideas.
I stopped late Friday at the local steel supplier. I got some tubular steel ordered for the vertical and horizontal parts and some triangular steel for where the vertical meets the horizontal. Cost of the reinforcement steel was about $100.
I realize late Friday is not a good time so I paid and told the guy I'd pick the order up Monday after I get off work.
I used one of those to mount my PTO generator on.
Welded on a roof to keep the rain off the generator itself, and legs to set it on the ground so that the PTO shaft stays level, and hydraulic bleed off on the 3pt won't affect driveline on long running times.
Nice set-up ! This is off topic but I am curious as to how much fuel you use, per hour say, running a rig like that. I realize it depends on the load but I'm just trying to get an idea. Thanks
gg
It'll make it stronger.Nothing welded yet and nothing even clamped. Everything is loose but approximately where I want it. Triangular steel where the vertical meets the horizontal. 1x3 on the vertical, 1x2 under the horizontal.
What do you guys think?
For sure.!What will you be lifting with the carry-all? If it needs to be stronger, the joint between the vertical and horizontal would be my focus. I would think adding a 3x3x1/4" angle the full width in the corner would make a big difference. I use my carry-all on the front of my Toolcat and stacked it full with firewood no problem.
