Given the current prices in 2025, what are your thoughts on PT422 over PT425?
/ Given the current prices in 2025, what are your thoughts on PT422 over PT425? #1
yim
Power Trac PT425
Hi guys, I've been reading a lot of great information on Power Trac on this forum so thanks to everyone that posts here. Most people are recommending that if you are going to buy new you might as well upgrade to the PT425 but seems like most of the comments on here are from some years back when the price difference was only a few thousand. Currently, the PT425 is $4,300 more than the PT422... that could buy a lot of attachments. I was planning on get the 425 but I'm leaning more and more to the 422 now.
The 425 has
- Bigger wheel motors
- 8" higher lift
- ROPS
- Can use the 60" mower
I think you can add the ROPS to the 422 and I'd use the 48" mower because I'm mowing areas with a boatload of trees to get around. That leaves the higher lift and bigger wheel motors. I'm on 4.5 acres that is pretty flat and I'll just be using it around the property for basic mowing, landscaping, etc type stuff so I'm not sure those 2 things are worth the extra 4,300. What do you guys think? When would you choose the 422 over the 425?
/ Given the current prices in 2025, what are your thoughts on PT422 over PT425? #2
That is a tough decision. I was always aggravated by the errors in the specs on the machines. For example the weight between the two (425-1387 and 422-1344) is 43 lbs different! Yet the 425 is supposed to have a 8" longer wheel base (but the overall length is only 6" difference). So the 43 lbs heavier weight of the 425 is attributed to the 8" longer wheel base and larger engine is there any more for longer loader arms to account for the increased height? Or just longer cylinders? By memory when I was shopping for them maybe 8 years ago, the sizes of the 422/425 were identical. Just the 425 had 2 steering cylinders, ROPS and larger engine. I think the specs even say the 422 has no cooling fan but the pictures shows one. You almost have to go look for yourself in person. Unless they changed them, I bet they have the same lift specs (if same tire size).
The lift height is a big concern if you only have one machine and you figure the many many years you will be using this and the times when just a little more height could have gotten the job done.
If you find that the lift heights are in fact the same, I would go with the 422. I have the PT180 and love it (but with conditions). Like you, I have many trees to cut around but then add in 5 times as many rocks which are just about everywhere at my place. The 018 has small deck but I don't think there is a machine made anywhere for any price that can keep up with the nimbleness of it! I can't say that enough. I have a diesel 430 but still use the 018 for the rough rocky areas (and the fact that I have more control of the deck). It tends to be a lot of brushy/woody material and I probably only run the engine at 1/2 throttle or less and it does great (except for the sparse grasses which it will only cut about 95%) so more than enough horse power proportional to the size. All my PTs have a problem with heat rejection, I watch the hyd oil temp and switch to a different task when they get to hot.
The 180 has some advantages over the other PTs with the more simple cylinder arrangement for the loader arms. It allows for a vastly larger degree of rotation of the attachment (to the point of being dangerous). You can roll the bucket back so far it will start to dump toward the operator if you are not careful. And you can lift the mower so it is cutting 90 deg to the ground and cut back vegetation that crowds in along the fields.
The vintage 018 I have has more then enough wheel torque for all conditions. I actually have a problem not spinning the front wheels a bit when starting off. Don't know how the 422 compares.
Good luck with your purchase and enjoy the research.
/ Given the current prices in 2025, what are your thoughts on PT422 over PT425? #3
I have also wondered how these units compare and wondered what recommendation Terry at PT would offer?
60" deck will cut more acres faster than 48", especially considering that you may lose 6 inches or more on each cutting pass due to overlap. 25hp IMO isn't that much for cutting tall vegetation, especially when part of that HP is being run through a hydraulic system.
m4050, appreciate the insight. The 180 sounds like a great little machine. I do wonder if having the extra lift height of the 425 is worth an extra 4k+. I don't think I need the extra wheel torque because I'll just be doing weekend warrior type projects around the house, but I've never own any kind of tractor before so it's all new to me.
2manyrocks, I actually called PT last week and posed this same question. The person I talked to on the phone said that given my situation the 422 could be a better option. They said I could come try em all out and see. (I'm only 3.5 hours away). I appreciate a company that isn't always trying to upsell you into the more expensive model.
/ Given the current prices in 2025, what are your thoughts on PT422 over PT425? #5
If you can swing it, I highly recommend going to visit the factory and trying out the models that you think you want, and some of the attachments. For me it confirmed my choice of model, and convinced me to buy some and not other attachments. I found the trip very well worth it. Plus, you get to meet the team!
I found the 1850 on the 45 degree tilt table in the showroom eye popping.
All the best,
Peter
/ Given the current prices in 2025, what are your thoughts on PT422 over PT425? #6
If only 3.5 hours away…. That’s a no brainer! You’ve gotta go try em all!
I believe when I bought my 425 it cost 10,500 vs 8,500 for the 422. I personally don’t know what I would do without the ROPS. What else would you hold onto?😂 That does seem to be quite a price difference between the two. I definitely prefer the dual steering cylinders of the 425 and that there is deeper footwells because of the different engineering in mounting the single steering cylinder of the 422. Yupp…. You’re going to have to take a road trip.
Kris
/ Given the current prices in 2025, what are your thoughts on PT422 over PT425? #7
We have to remember that there isn't 25HP available to spin the mower deck. We've done the math before in this forum and the main hydraulic PTO output is about 13hp. There's a formula in regards to gallons per minute, psi of the system, RPM of the pump, etc... I'd have to re-do the research to get the exact numbers, or search for that thread.
/ Given the current prices in 2025, what are your thoughts on PT422 over PT425? #8
At times I wish I had spent the extra $$ for the 425. A larger mower deck would cut down on the 2.5+ hours it takes to do a complete cut(apprx. 3.5 acres). That's a lot of time running the tractor and takes it toll on both the tractor and yourself, so I cut half the area one day and the other half the next day providing weather cooperates. I find the mower handles tall weeds w/o much trouble and if I feel it will be a problem I do 2 cuts with the 1st being 6+ inches above ground. I'm glad I didn't spring for the brush hog, 48" deck seems to handle it.
Otherwise I rarely miss the addl lift height or the HP. I don't have the ROPS and use the seat or its arms to hold onto when traveling at extreme angles. Speaking of the seat, that's one area needing improvement along with eliminating the 90 degree turn on the exhaust pipe to the muffler. I changed that when I installed the fan to suck heat out of the cage and the engine runs considerably cooler.
The PT is some of the best $$ I ever spent, you'll probably agree down the road. I bought mine w/o a chance to test drive one..go to Tazewell if you can!
/ Given the current prices in 2025, what are your thoughts on PT422 over PT425? #9
For the 425, a PTO of 8gpm @2500psi equates to about 7.5HP (flow x pressure/1714 for SAE units, assuming a typical 85% efficiency)
All the best,
Peter
/ Given the current prices in 2025, what are your thoughts on PT422 over PT425? #10
What's the PTO HP of the 422 based on its 8gpm@2,000psi? And what practical difference does the extra PSI of the 425 otherwise make other than being able to run a 60" cutter versus a 48" cutter?
422 manual quick attach wouldn't bother me. Not having a ROPs would bother me a lot. Even if someone (not me) argued it has no other benefit on flat land, it's a very effective sunshade.
Weight of the 422 1344 lbs versus 1387 for the 425. Same width. 800lb lift capacity for both models.
The Kohler engine in the 425 is a known good engine. Don't know anything about the engine in the 422.
/ Given the current prices in 2025, what are your thoughts on PT422 over PT425? #11
All the best,
Peter
pressure times flow rate / 1714
2500 x 8 =20,000 = 20,000
20,000 / 1714 = 11.669
/ Given the current prices in 2025, what are your thoughts on PT422 over PT425? #12
In your situation, why did you pick the 425 over the 422, Moss Road?
/ Given the current prices in 2025, what are your thoughts on PT422 over PT425? #13
9.33HP VS 11.67HP
As Terry described it, it'll keep the blades spinning better.
And if you use a brush cutter, same thing.
/ Given the current prices in 2025, what are your thoughts on PT422 over PT425? #14
At the time, 2001, I did a horse power per dollar cost. The two units were the same dollar per horsepower, I got a free ROPS and two steering cylinders and higher PSI on the PTOs. The lift heights were the same at the time. Today, the 425 lifts higher than mine. There are many times I've wished for a little higher lift. I've always gotten around it with unoriginal ingenuity (build a ramp, dig a trench, find a hillside, etc...) :ROFLMAO:
I needed the 60" mower and Terry said he'd only suggest the 48" mower for the 422. I wanted to mow our 1 acre, 4 ball diamonds at the Little League Park, and my wife's church ball diamond. So bigger was better.
I also wanted the 48" brush cutter, and we have a very hilly piece of property, so the higher HP would help with that.
So let's compare today's 422 to 425.
422 is $11,600 / 22hp =$527.273/HP
425 is $15,900 / 25hp =$636/HP
So about $110/hp more.
You also get free ROPS, two steering cylinders, larger wheel motors (that's a big plus for me) and an 8" higher lift.
I don't know what to tell the Original Poster. I've always been a fan of getting the biggest motor in a platform that was available. The platforms were equal back then. Today, they are different with the higher lift and bigger wheel motors; both things I wish I had today.
My best advice would be not only listen to what members/owners here say, but go to Power Trac and get some seat time. Pick their brain.
/ Given the current prices in 2025, what are your thoughts on PT422 over PT425? #15
I'd really like to drive a new 425 to compare it to my 2001 model. I really abuse mine, pushing it to the max lift limit often, mowing in high summer temps, and bushwhacking new trails. I'd like to see how it does under load on our hills.
/ Given the current prices in 2025, what are your thoughts on PT422 over PT425? #16
The question of whether to buy a 422 v 425 has been discussed in a couple of older TBN threads. There were some members who posted their opinions in those older threads that haven't posted in this one. I'd suggest using the search tool to find and read those older threads.
One member in the past said he'd spend more for the 425 to get the larger wheel motors, the ROPs, the ability to power a 60" cutter and the Kohler 25hp engine. Another had the opinion that the additional lift height of the 425 was important to him.
/ Given the current prices in 2025, what are your thoughts on PT422 over PT425? #18
Everything depends on your specific needs and circumstances, like most things in life. For perspective, I own two 425s and an 1845, all purchased used. On one of the 425s, I upgraded both the wheel motors and the engine (to 35 HP).
On hilly terrain (which you don't have, but others will read these comments) using the 60" mower, I find the standard 425 to be a bit underpowered. That assessment comes from personal experience as well as extensive calculations. But would a 422 with a 48" mower be worse? Hard to say. On level ground, you might not even notice the difference.
Regarding lift height, those extra 8 inches can make a big difference in certain situations—like loading material into a trailer or using forks to unload cargo from a tall trailer such as an 18-wheeler.
When it comes to attachments, you may not need many. For me, the sweet spot includes the mower, a bucket, and a set of forks. Everything else tends to sit mostly unused. Although I own other machines now, I’m considering this from the perspective of when I relied on the 425 for everything.
Personally, I’d definitely choose the 425 again—for the extra horsepower, larger wheel motors, higher lift capacity, ROPS (I'd had several branches fall on the ROPS), and dual steering cylinders (assuming that hasn’t changed). For the work I do most often, I’d prioritize those built-in features over collecting more attachments. I have lots of attachments, as part of the used package deal, that have never been used.
In the end, it's a difficult choice if you have level ground (as you mentioned). If you don't, then it's an easy choice in my opinion.
/ Given the current prices in 2025, what are your thoughts on PT422 over PT425? #20
$4,300 spread over 20 years of ownership would be $215 per year not considering the net present value of how those funds might have been otherwise invested.
But I really want to emphasize using the search tool to read prior discussion threads because they may contain some very useful insights that have already been posted. Some of those members may be no longer active, but their insights are still valuable.
Club Car Electric Utility Cart (A55851)
Club Car Electric...
Chance Quick Attach 78" Screening Bucket (A60463)
Chance Quick...
2020 Broyhill Load and Pack Articulated Solid Waste Handling Vehicle (A59228)
2020 Broyhill Load...
2022 John Deere 1025R (A53317)
2022 John Deere...
2005 LEEBOY 685B MOTORGRADER (A62129)
2005 LEEBOY 685B...
(4) Dura Trench Drain Grates (A60463)
(4) Dura Trench...
