Typhon Terror XVII with cab.
   / Typhon Terror XVII with cab. #1
MattB4
Gold Member
Cat 262 skid and Typhon XVII
After selling my Typhon Mark X (1-ton gas powered) mini Ex 3 weeks ago I ordered in a new 2-ton rated XVII with the Kubota diesel D902 in it from Ebay Seller MachineryUSA. I offered $11,599 and it was accepted. The total price with tax was $12,435.93 (includes my bank wire fee of $25). The deal includes free shipping and I got the Excavator last evening at 5-6pm. The driver called me only a couple hours before showing up.
Shipping was on a large Sleeper Semi with a 53ft drop deck which I was not adequately prepared to receive out on the rural county road I live on. Finding a place for this large of a loaded truck to turn around meant traveling from my house about 3/4's of a mile. It also meant that after unload I had to shuttle the excavator back home. That took most of an hour at teh extreme slow speed of the machine. The truck driver, while a nice fellow, did not operate or unload. He seemed to be a foreigner with not the best grasp of English which complicated understanding. At least the truck came with a nice set of double ramps that meant unload was not entirely difficult although the middle ramps support meant using the bucket to stabilized the ex was a bit tight. Likely a person not used to running an ex would be a bit overwhelmed by this.
As I get some time I will flesh out my review. Some initial impressions are that it is definitely a big improvement over my previous 1 Ton. The diesel engine and pilot controls improve operation enormously. Some negatives I discovered are the slow travel speed, the engine heats up the seat area considerably after running at high throttle for more than 1/2 hour (thankfully the Aircon works some or the trip back to my home in the upper 80F's would have been hard to take.) I noticed no issue though with engine overheating. The cab is very small for my 6ft-3in size. It does seem to be fairly matched to the zero tail turn unit with only a few areas where I need to add some foam to close gaps. The seat in full back position vibrates against the back glass. But the controls have full movement in front.
Your photos are huge, like to see them but....
Sorry about that. I will take some with my digital camera instead of using my phone. Its resolution is less making for a smaller file size. Are the thumbnails too large to show up in the first post?
   / Typhon Terror XVII with cab. #4
Here is a photo that's just 150-+kb. Seems OK to me.
You did not answer if you could see the thumbnails instead you just got snorky. Ignore my Threads if you can not control your attitude.
   / Typhon Terror XVII with cab. #7
Snorky? Of course I see the thumbnails but if you click one, you DLed them all. I posted the one photo to show its quality.
Once again. Just go away.
   / Typhon Terror XVII with cab. #9
Don't forget, "please change the filter element if it's broken or there's too many dirt"
Please change the air filter position while your at it - the clean out is meant to point down.
   / Typhon Terror XVII with cab. #10
Nice looking machine Matt - yes they are slow but you knew that going in. The blue looks good - seems to be a Hightop made unit. I see they have some nicer pedals now, and a little better fit and finish than mine a year ago.
You will need to stiffen up the thumb welding some plates between the tines, other than that run it!
2017 FREIGHTLINER M2 106 (A53843)
2017 FREIGHTLINER...
2017 DRAGON ROLL OFF TRAILER (A55745)
2017 DRAGON ROLL...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A51691)
2019 Caterpillar...
1990 Ford F-450 Heil 10FT Dump Truck (A55852)
1990 Ford F-450...
2013 PETERBILT 389 SLEEPER (INOPERABLE) (A55745)
2013 PETERBILT 389...
2005 Ford Explorer 4X4 SUV (A53424)
2005 Ford Explorer...
