   / Share Pics of People Hauling or Towing Something Wrong #22,651
After a couple close calls, I've started using carabiners thru that loop to attach the strap to the hooks on the trailer. At least if it loosens up you don't lose the strap.
I'll also criss-cross the straps on each side ie strap to the back of the snowmobile/atv to the front hook on the trailer, and vice versa. Lot less likely to loosen that way.
Mine was in the back of my truck. I ran the strap across the bed, wrapping it around the rear rack. I hit a good bump but never considered the strap could stretch enough to release.
Now I tie an insurance rope onto the steering assembly, just a square knot kn case something doesn't go as planned.
   / Share Pics of People Hauling or Towing Something Wrong #22,652
I use nothing but ratchets with snap hooks. They can't possibly fall off.
Used zip ties to secure the excess strap, but have recently switched to short hook and loop straps. They're faster to undo and obviously reusable.
   / Share Pics of People Hauling or Towing Something Wrong #22,653
These are great. Keeps them stored on the road and behind the seat.
   / Share Pics of People Hauling or Towing Something Wrong #22,654
Snap hooks are great, when they're new! But I've yet to meet one that I didn't destroy inside of a few uses. I usually end up cursing myself for buying those things, as I busy myself with a grinder, converting them to regular hooks.
   / Share Pics of People Hauling or Towing Something Wrong #22,655
   / Share Pics of People Hauling or Towing Something Wrong #22,656
I use the non-adjustable versions of those to secure rolled-up ratchet straps during storage so they don't unroll.
I do too and use them to hold the excess tail. I never "adjust" them, just wrap again or stretch more.
   / Share Pics of People Hauling or Towing Something Wrong #22,657
The adjustable ball bungees might work better in some cases for me because the regular sized ones are a tight fit with the bigger ratchet straps. I need to get me some.
Only bad thing with those is the shock cord tends to lose it's integrity after being stretched out for a while.
   / Share Pics of People Hauling or Towing Something Wrong #22,658
Are you talking about snap hooks like these two inch ones? These are six or seven years old and still in great condition. I never throw the hook. If I am going over something while tying down, I throw the rolled up webbing over.
While using them, I either clip them onto a "D" ring or run an axle strap through a stake pocket, etc. then clip the hook onto the axle strap rings.
   / Share Pics of People Hauling or Towing Something Wrong #22,659
There were times when I managed to distort the thin material of the clip, but it was easy enough to make them work again. These days I have better anchor points (like QRTRHRS) and haven't had any issues.
I still have and use my first ratchet straps from the early '90s. They must have several hundred uses on them by now. Have largely switched over to the twisted hook version, and lasso straps and/or wheel nets, but regular ratchet straps are also still used, almost every time.
Have seen way too many straps with open hooks that have come off, either along the road or as people arrive in camp - thankfully, so far with their vehicles still on the trailers.
   / Share Pics of People Hauling or Towing Something Wrong #22,660
I wear out or cut the strap before my hooks fail. Mine come from Custom Tiedowns. Not cheap but worth it. I have d-rings in all the stake pockets and use axle straps in between on the round rub rail support.
Product 2787
2015 Ford Escape SUV (A56859)
2015 Ford Escape...
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
20ft Shipping Container (A57453)
20ft Shipping...
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
2016 Chevrolet Tahoe SUV (A56859)
2016 Chevrolet...
2014 Komatsu D51PXI-22 (A55272)
2014 Komatsu...
