ernemats
- Joined
- Mar 29, 2002
- Messages
- 1,099
- Location
- Bolivar, pa.
- Tractor
- power trac 422, and agco-allis 5660, ,1845 power trac Greenworks CRT 426
Was mowing today on a fairly steep slope about 25 degree slope when it suddenly acted like it was low on fuel. Checked about 2 inches at fuel outlet , put more fuel in so there was plenty of fuel . Tried to start numerous times , no click when key turned to first position which usually makes. Turned to start and it acts like it usually does spinning motor still no start. Checked wires they seem ok. Yesterday when I ran it it ran fine for about 1/4 mile then smoking shut it off , lifted the hood and started it fuel flying all over motor and muffler. Managed to get it back to shed took side cover off mouse nest in by injectors they had chewed the return fuel line off. Fixed with new hose seemed ok no more leaks. Sprayed engine and radiator off with cleaner and rinsed off with garden hose. Mowed for about 1 hour till it shut off and would not start. Any ideas on what I should check?
