JD 4052R - What is this connector??
   / JD 4052R - What is this connector?? #1
LouieJunior
Moline, Illinois
JD4052R Open Station
Hello - I was washing my tractor this morning and discovered a damaged connector. I don't know what it's function is. Everything has been operating okay, as far as I know. The connector is at the rear of the tractor - behind the seat, inside the left rear wheel. Does anybody recognize this? It has a metal mount, intended to hold the connector in place. When discovered, mine was dangling outside of the holder. Pictures attached... Thanks!!
   / JD 4052R - What is this connector?? #2
Looks like a reverse beeper to me rather than a connector.
There is a sticker on it. Have you read what it says?
I also spy a switch on that purple wire. Wondering if it's to turn that beeper on and off.
Thanks - If that is what it is, all I am missing is the female threaded ring to tighten it and hold it in place. My reverse beeper still beeps.
   / JD 4052R - What is this connector?? #4
Maybe it is the 4052R ?
   / JD 4052R - What is this connector?? #6
Looks like a Sonalert, you probably won't be able to get the ring to secure it without buying the whole unit. A small ring of latex caulk will hold it in place, especially if the wires are tied off as well. They really should put a switch on them, so they can be turned off when you're by yourself with noone else around, annoying little gits.
1983 INTERNATIONAL S SERIES WATER TRUCK (A52707)
1983 INTERNATIONAL...
16001 (A55853)
16001 (A55853)
New Holland S68 Square Baler (A56438)
New Holland S68...
296385 (A57192)
296385 (A57192)
2014 Chevrolet Express 3500 Cargo Van (A55852)
2014 Chevrolet...
SHOP BUILT TOOL TRAILER (A58214)
SHOP BUILT TOOL...
