BX2230 mid PTO problem
/ BX2230 mid PTO problem #11
What I have found on my BX23 is clean an use lite lube....in this case less lube allows less attraction for dirt. Each time before I mount MMM I pull the shaft off the MMM deck and slip it onto the PTO...If problem I clean the PTO shaft an collar and try again. Then all I need to do is line it up...not always easy but at least I know that the collar slipping on is not the problem...This also is great practice with the MMM out of the way. Oh another thing I do is in-gang the MMM PTO so that it does not turn while turning the coupler/shaft.
/ BX2230 mid PTO problem #12
...Still, one of the ball bearings is more difficult to retract if I pull the collar back when I have operated the collar when off the tractor. There is no sign of any detent.
Sounds like there's still crud/corrosion in collar...Next time it's off I'd repeatedly solvent soak and use compressed air until freed up and collar stays retracted...
KENT HYDRAULIC HAMMER ATTACHMENT (A60736)
KENT HYDRAULIC...
2021 Ford F-250 4x4 Crew Cab Pickup Truck (A59230)
2021 Ford F-250...
BE HW4013HG HOT WATER PRESSURE WASHER (A59823)
BE HW4013HG HOT...
2020 LCMG AS1932E ELECTRIC SCISSOR LIFT (A59823)
2020 LCMG AS1932E...
2019 KUBOTA KX033-4 EXCAVATOR (A60429)
2019 KUBOTA...
2019 F-550 Bucket Truck (A61307)
2019 F-550 Bucket...
