Replacement hose 3510 ML112 Loader hose?
/ Replacement hose 3510 ML112 Loader hose? #1
DiskDoctr
Western PA
Mahindra 3510
I am looking to replace the front loader hoses on my 2004 3510 "New Sheet Metal" with ML112 loader. They are 18 inches long. Am I right that they are 3/8" JIC?
Are they 8F or 6F swivels?
Part number is 22506506018 (#3 in the PDF of the diagram out of the manual)
Standard part has swivels on both ends:
3/8" x 18" JIC 8F Swivel x JIC 8F Swivel SAE 100R16 Hydraulic Hose Assembly 5000 PSI NRP Jones | NRP Jones | Brands | www.surpluscenter.com
If I know 8 or 6, I can just order a standard hose and add a nipple to the steel line and use standard hoses, right?
Thanks.
  • ML112 Hoses diagram from manual.pdf
/ Replacement hose 3510 ML112 Loader hose? #2
Thanks.
Honestly, the easiest way to do this is gonto a local NAPA and see of they make hoses in house. Mine did and I was back online in a few hours. Jist took tje hose with me and they matched it all up.
About how much was a hose? Cost is a major factor as to why I want to use standard hoses
Adding this chart of JIC sizes
/ Replacement hose 3510 ML112 Loader hose? #5
That's the standard sizes, but often a certain hose size will come with a different size fitting.
Yeah, lots of confusion. If someone doesn't know for sure, I'll probably start ordering some hoses and adapters, trial and error.
I ordered this kit to help identify JIC now and in the future.
Added benefit is ability to cap or plug lines or fittings, such as when taking hoses off to get made up or identifying, etc.
Anyone else use something like this?
https://www.amazon.com/dp/B0D2MNWBRY
