Need Radiator
/ Need Radiator #1
capitalcajun
Mitsubishi MTX 245
I have a Mitsubishi MTX 245. In need of radiator new or used. Can someone point me to a parts source: capitalcajun@yahoo.com or 3373220965 Thank YOU!
/ Need Radiator #2
Try a Mahindra dealer. First Turn in Lafayette is a Mahindra dealer
/ Need Radiator #3
If it's just a few tubes leaking just crimp it with a pair of pliers.
/ Need Radiator #5
Your radiator is old enough that it should be repairable. Look for a local radiator repair shop.
That's a thought from the past Roadworthy! There are no more radiator shops anywhere - they'd all rather just replace - not repair! Plus, regulations forced most out of business.
/ Need Radiator #6
Not true. These people did my 1980 Ford 1900 gazillion dollar radiator when it had some leaks and plugged up a bit inside. They soldered the leaks, cleaned it up and I put it back on for another set of years use. At the time it was already 40 years old.
/ Need Radiator #7
And that is California for you!
/ Need Radiator #8
Tell me please - Tractor Tech - I follow and appreciate everything you've said in this forum - but is that statement meant to be a + or -? Seeing as you sign in from Ca also!
I do agree that Calif has shot down any attempts for shops to comply with the general publics wishes. There used to be radiator/battery rebuild shops in Oceanside (this former Marine knows!) but they have disappeared. One can only assume it's due to severe regulations. That's the shame on Ca. for small businesses.
SARLO (A64557)
SARLO (A64557)
2020 Polaris Ranger XP 1000 UTV (A65579)
2020 Polaris...
2006 Ford F450 XL Super Duty Swab Rig (A62679)
2006 Ford F450 XL...
2020 FORD F-550 CAB AND CHASSIS (A65643)
2020 FORD F-550...
New/Unused Wolverine 72in Quick Attach Brush Cutter (A65583)
New/Unused...
2019 FORD F-350 (INOPERABLE) (A65643)
2019 FORD F-350...
