BX24 blowing hydraulic filters
/ BX24 blowing hydraulic filters #1
Suki
Member
LS 3040i
We have a BX24 and about 10 hours of work after disconnecting the backhoe, it blew the hydraulic filter. It was replaced and it happened twice more. We just changed the pressure relief valve and are waiting on a gauge to test. Anyone have any insight on this matter and are we missing something?
/ BX24 blowing hydraulic filters #2
does this unit need to be plugged back into the 3 point for the return?, you didn't leave all the hoses disconnected did you?
Yes it was. It seems like there is too much pressure. My brother took out the relief valve and it had no shims and he put 4 back in. We will test when gauge arrives tomorrow.
/ BX24 blowing hydraulic filters #4
Yes it was what?
Everything worked well for about 10 hours of work and then I went and mowed the lawn. We did add a three point hitch.
/ BX24 blowing hydraulic filters #8
Is there a screen in the hydraulic system? I had a BX several years ago and can’t remember. Edit, it does look there is a screen. Did you clean it?
/ BX24 blowing hydraulic filters #11
Did it happen once you started using the 3pt?
Or using the deck lift?
/ BX24 blowing hydraulic filters #12
doesn't adding shims increase the pressure?
Sure does and without a liquid filled pressure gage, that is playing with fire...
Pays to know what you are doing before you do it...
Reading along, I'm thinking the OP has the hoses incorrectly hooked up. I'll follow along to see the outcome...
Is there still on old gasket on the mounting surface by any chance? Were the filters tightened to spec?
I will double check but we checked all that. Not sure why it happened in first place as it had been in place for almost 10 months.
Cheap aftermarket filters or genuine Kubota fikters? You realize there is internal pressure on the hydraulic filter?
We have Kubota filters.
It was plugged back in.
I will find out and check it.
Kubota only.
/ BX24 blowing hydraulic filters #19
I’m pretty sure they do have a suction screen, which can get pretty clogged. I don’t know if that coukd cause the filter to keep blowing off.
/ BX24 blowing hydraulic filters #20
That's about what I am thinking. 5030. Tractors have a lot of built-in safeguards against too much hydraulic pressure. Hard to imagine everything failing and high pressure resulting.
Yes, the "adding shims to the relief valve" thing scares me too. I can't think how adding shims to a relief valve is going to lower the pressure. Usually it raises pressure.
A gauge test set is a good idea, everyone should have one. 5000 psi and liquid filled - Amazon has complete guage, hose, and adapters in a kit for less than $100.....sounds like the OP spent that much on hydraulic filters.
Suki, are you sure that the engine oil and the hydraulic filter didn't get exchanged? The hydraulic filter costs twice as much, it's heavier, and the shell is thicker. But they are about the same size and mounting.
I believe that model does have a cleanable screen under the hydraulic filter. But if it is clgged or missing it usually causes the opposite problem - too little pressure rather than too much. However, if it is missing or installed wrong it can cause a leak that might make you think the hydraulic filter "blew". You might want to describe how it blew. BigNoise? Or just lots of oil??
By far the most common hydraulic overpressures are caused by hoses. Either the quick connect ends are not seating well or the hoses are connected to the wrong ports. While waiting, I'd take them all off - one at a time - inspect them and make sure the connections are correct. Push on the quick change valves with something to make sure they are seating. And check for a mysterious oil leak or split down by the cooling fan underneath. That's a known trouble spot.
Luck,
rScotty
19008 (A56859)
19008 (A56859)
UNUSED FUTURE FT15 EXCAVATOR (A60430)
UNUSED FUTURE FT15...
2007 Ingersoll Rand P185 S/A Towable Air Compressor (A59228)
2007 Ingersoll...
2004 Ford F-550 Miller 301 Wrecker Truck (A55852)
2004 Ford F-550...
UNUSED IRANCH SEMI AUTOMATIC QUICK CHANGER (A60432)
UNUSED IRANCH SEMI...
FRESHLY REFURBISHED! 2016 KBH Fertilizer Tender Trailer - Isuzu Diesel (A61307)
FRESHLY...
