BX24 blowing hydraulic filters
   / BX24 blowing hydraulic filters #1
Suki
Member
LS 3040i
We have a BX24 and about 10 hours of work after disconnecting the backhoe, it blew the hydraulic filter. It was replaced and it happened twice more. We just changed the pressure relief valve and are waiting on a gauge to test. Anyone have any insight on this matter and are we missing something?
   / BX24 blowing hydraulic filters #2
does this unit need to be plugged back into the 3 point for the return?, you didn't leave all the hoses disconnected did you?
Yes it was. It seems like there is too much pressure. My brother took out the relief valve and it had no shims and he put 4 back in. We will test when gauge arrives tomorrow.
   / BX24 blowing hydraulic filters #4
Yes it was what?
Everything worked well for about 10 hours of work and then I went and mowed the lawn. We did add a three point hitch.
   / BX24 blowing hydraulic filters #7
Is there still on old gasket on the mounting surface by any chance? Were the filters tightened to spec?
   / BX24 blowing hydraulic filters #8
Is there a screen in the hydraulic system? I had a BX several years ago and can’t remember. Edit, it does look there is a screen. Did you clean it?
GEARMATIC WINCH CABLE DRUM (A58214)
GEARMATIC WINCH...
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
Kubota M108S (A53317)
2021 MULTIQUIP 25 WHISPERWATT DIESEL GENERATOR (A59823)
2021 MULTIQUIP 25...
*Selling at Royal Auction Zephyrhills, FL Location* (A59228)
*Selling at Royal...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
