BX24 blowing hydraulic filters
   / BX24 blowing hydraulic filters #1
Suki
LS 3040i
We have a BX24 and about 10 hours of work after disconnecting the backhoe, it blew the hydraulic filter. It was replaced and it happened twice more. We just changed the pressure relief valve and are waiting on a gauge to test. Anyone have any insight on this matter and are we missing something?
   / BX24 blowing hydraulic filters #2
does this unit need to be plugged back into the 3 point for the return?, you didn't leave all the hoses disconnected did you?
Yes it was. It seems like there is too much pressure. My brother took out the relief valve and it had no shims and he put 4 back in. We will test when gauge arrives tomorrow.
   / BX24 blowing hydraulic filters #4
Yes it was what?
Everything worked well for about 10 hours of work and then I went and mowed the lawn. We did add a three point hitch.
   / BX24 blowing hydraulic filters #7
Is there still on old gasket on the mounting surface by any chance? Were the filters tightened to spec?
   / BX24 blowing hydraulic filters #8
Is there a screen in the hydraulic system? I had a BX several years ago and can’t remember. Edit, it does look there is a screen. Did you clean it?
Hustler super Z zero turn (A56859)
Hustler super Z...
2022 Magni TH5 5.19P (A56435)
2022 Magni TH5...
2013 Chevrolet Traverse AWD SUV (A56859)
2013 Chevrolet...
2015 DRAGON 130 BBL VACUUM TRAILER (A58214)
2015 DRAGON 130...
2012 International ProStar T/A Day Cab Truck Tractor (A56858)
2012 International...
2005 INTERNATIONAL 9400I MID-ROOF SLEEPER (A58214)
2005 INTERNATIONAL...
