BX24 blowing hydraulic filters
/ BX24 blowing hydraulic filters #1
Suki
Member
LS 3040i
We have a BX24 and about 10 hours of work after disconnecting the backhoe, it blew the hydraulic filter. It was replaced and it happened twice more. We just changed the pressure relief valve and are waiting on a gauge to test. Anyone have any insight on this matter and are we missing something?
/ BX24 blowing hydraulic filters #2
does this unit need to be plugged back into the 3 point for the return?, you didn't leave all the hoses disconnected did you?
Yes it was. It seems like there is too much pressure. My brother took out the relief valve and it had no shims and he put 4 back in. We will test when gauge arrives tomorrow.
/ BX24 blowing hydraulic filters #4
Yes it was what?
Everything worked well for about 10 hours of work and then I went and mowed the lawn. We did add a three point hitch.
/ BX24 blowing hydraulic filters #8
Is there a screen in the hydraulic system? I had a BX several years ago and can’t remember. Edit, it does look there is a screen. Did you clean it?
2012 TROXELL 130 BBL STEEL (A58214)
2012 TROXELL 130...
500BBL SKIDDED FRAC TANK (A58214)
500BBL SKIDDED...
2003 POLAR TANK (A60736)
2003 POLAR TANK...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
ASSET DESCRIPTIONS & CONDITION (A59906)
ASSET DESCRIPTIONS...
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
