Flail mower for grinding up brush piles
   / Flail mower for grinding up brush piles #2
Mine would. I'd probably spread the pile into a 'line' to make it easier to drive over.
I have hammers and they are heavy. Up to 2" brush would be easy.
   / Flail mower for grinding up brush piles #3
My Ford 917 will do it but the true 2” chunks likely won’t be shredded.
   / Flail mower for grinding up brush piles #4
It'll splinter and spread the wood out more than it will grind it up. At a certain point, you would be better off with a wood chipper or burn it.
   / Flail mower for grinding up brush piles #7
What model flail do you have?
   / Flail mower for grinding up brush piles #8
I've got a cheap Chinese Nova, but support is great from Jack. Mine is the BCRM, medium duty ditch mower with the hammers, not knives. I don't have a lawn to maintain.
It's not a chipper, but it does 80% of the chipper work in about 5% of the time. I also burn the big stuff.
   / Flail mower for grinding up brush piles #9
FWIW, the operator who did some forestry mulching for me said it was harder to grind up material laying on the ground. I watched him obliterate small standing trees in minutes, but he had trouble grinding up the same size material if it was on the ground. He was using a Cat forestry mulcher with carbide teeth and Cat CTL.
   / Flail mower for grinding up brush piles #10
I used to burn brush piles. Later I chipped them. Now I pile brush in selected places, leave it alone, and get to watch more wildlife.
Bruce
207275 (A52708)
207275 (A52708)
2011 Toro Workman HD Gas Utility Cart (A59228)
2011 Toro Workman...
2004 Ford F-550 Miller 301 Wrecker Truck (A55852)
2004 Ford F-550...
2019 CATERPILLAR 326FL EXCAVATOR (A60429)
2019 CATERPILLAR...
Booster Cables (A59230)
Booster Cables...
2006 TerraGator 8104 (A56438)
2006 TerraGator...
