Flail mower for grinding up brush piles
   / Flail mower for grinding up brush piles #2
Mine would. I'd probably spread the pile into a 'line' to make it easier to drive over.
I have hammers and they are heavy. Up to 2" brush would be easy.
   / Flail mower for grinding up brush piles #3
My Ford 917 will do it but the true 2” chunks likely won’t be shredded.
   / Flail mower for grinding up brush piles #4
It'll splinter and spread the wood out more than it will grind it up. At a certain point, you would be better off with a wood chipper or burn it.
   / Flail mower for grinding up brush piles #7
What model flail do you have?
   / Flail mower for grinding up brush piles #8
I've got a cheap Chinese Nova, but support is great from Jack. Mine is the BCRM, medium duty ditch mower with the hammers, not knives. I don't have a lawn to maintain.
It's not a chipper, but it does 80% of the chipper work in about 5% of the time. I also burn the big stuff.
   / Flail mower for grinding up brush piles #9
FWIW, the operator who did some forestry mulching for me said it was harder to grind up material laying on the ground. I watched him obliterate small standing trees in minutes, but he had trouble grinding up the same size material if it was on the ground. He was using a Cat forestry mulcher with carbide teeth and Cat CTL.
   / Flail mower for grinding up brush piles #10
I used to burn brush piles. Later I chipped them. Now I pile brush in selected places, leave it alone, and get to watch more wildlife.
Bruce
2025 New/Unused LandHero 16in Concrete Cutter (A51573)
2025 New/Unused...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2019 FREIGHTLINER...
2017 FORD F-650 FLATBED DUALLY (A52472)
2017 FORD F-650...
2017 Chevrolet Malibu 1LT Sedan (A51694)
2017 Chevrolet...
U56 ELECTRIC FIRE PUMP MOTOR (A51406)
U56 ELECTRIC FIRE...
