PTO Shaft to Gearbox Bolts Keep Breaking!
/ PTO Shaft to Gearbox Bolts Keep Breaking! #81
The bolt is not being sheared. It is being killed by countless rapid lateral shock loads that fatigue the metal at the weakest point...the bottom thread. I wonder how close a fit the hub and shaft are? There should be no slop there. What actual diameter are the holes in the hub and shaft?
/ PTO Shaft to Gearbox Bolts Keep Breaking! #82
Gust a SAWG, but I suspect a bolt hole is larger either on the PTO collar or the hole through shaft from the gearbox which is allowing the bolt to wobble eventually resulting in its fracture. I'd guess its the hole in the shaft from the gearbox.
Can you remove the shaft from the PTO collar and take a picture of just the bolt in the shaft showing the clearance between the bolt and the shaft hole?
Is it easy for the bolt to slide into the hole on the shaft?
That's really close to where I'd expect a shear with the threads under the collar.
I mean, I'd expect it to be right at the blue/green joint, but hey close enough.
I'll bet if you found the other piece of the bolt the threads would be mashed to smithereens and strangely the fulcrum is at the transition from one diameter (mashed threads) to another (bolt shoulder); it's probably been flexing back and forth at that spot, aided by the shaft hole being slightly larger.
Not a pure shear break so much as a work-weakening.
Just get a bolt with a longer shoulder and be done with this.
You're probably right.
Longer bolt in there now.
/ PTO Shaft to Gearbox Bolts Keep Breaking! #84
You said you were going to test with a bolt with a longer shank, have you had a chance to try that yet? Would be interesting to see what that looked like after a few hours of use. I'm thinking the threaded section is slightly smaller and allowing movement between the shaft and the collar on that side. At least with a shank that goes from collar to collar would give a better fit.
Does it matter which side of the collar you insert the bolt head in - i.e. is the bolt head always on the right, or is the orientation of the shaft, collar, and bolt head random?
Also, it looks like the bolt is spinning a lot in the hole. It "machines" a step on one side, and a groove on the broken side. Not sure what that means.
That is something I thought about. I could be inserting it the same direction each time simply because I'd have the nut/ratchet in one hand and wrench in the other so I could be always inserting from the left, so to speak.
I had put a longer bolt in it and it has about an hour or so on it.
Going to take a look once the storms pass.
Thing is though I use the 1/2 by 3 bolts on all of my cutters and this is the only one having issues!
May also swap out the shaft and see what happens.
/ PTO Shaft to Gearbox Bolts Keep Breaking! #87
It would be great if you could take and post some good closeup photos of the broken surface of the bolts, i.e. the actual fracture surface. Might give us a better clue as to what sort of failure it is. Right now, it is not looking like a shear failure.
/ PTO Shaft to Gearbox Bolts Keep Breaking! #88
I think it is similar to using a cold chisel to cut a steel rod. repeated blows cutting the loose bolt. The grain unloading drive on my JD 9500 only uses a 6mm bolt.
Here is a grade 5 on the left and grade 8 on the right.
/ PTO Shaft to Gearbox Bolts Keep Breaking! #90
I'm wondering if it's a combination of variables:
  1. The hole in the collar or shaft is slightly oversized or wallowed
  2. The bolt isn't long enough (collar rests on threads)
  3. The bold isn't tight enough - allowing it to spin and degrade
  4. There is some unusual vibration at the gearbox
  5. There are demons at play
/ PTO Shaft to Gearbox Bolts Keep Breaking! #91
Thanks for the photos.
The one on the left looks like a classic high-cycle fatigue failure: see all the striations. The one on the right looks more like a massive impact failure, but I am not sure.
And I am not sure what is causing this but am curious to learn!
/ PTO Shaft to Gearbox Bolts Keep Breaking! #92
One other question. So when the nut end breaks off, does the cutter continue to function, or does the bolt head end eject itself? If there is a substantial force on the gearbox, I would expect the bolt head end to also shear off when half the holding power (on the other half of the collar) has disappeared.
The bolt comes out also and is usually on the deck of the cutter. How long it stays in after breaking I don't know. Nut end is gone or I haven't found one yet.
I've learned to tell when it breaks or when the bolt comes out. It starts to sound like you ran over some cable or wire and got it tangled in the blades.
That is the first sign then the PTO shaft will come off the gearbox if you don't shut it off quick enough.
/ PTO Shaft to Gearbox Bolts Keep Breaking! #94
If that bolt were meant to be a "shear bolt", there would be a snap ring to keep pto hub from coming off the gearbox.
There is a slot for it on the input shaft but it is a monster pain to get the snap ring on and off.
/ PTO Shaft to Gearbox Bolts Keep Breaking! #96
There has to be something going on with the gearbox to have these quick impacts stressing the bolt. Is there a missing gear tooth? A bad bearing? Debris getting in the teeth? Stump jumper not attached solidly?
/ PTO Shaft to Gearbox Bolts Keep Breaking! #97
It might be that the nut backs off far enough that the load is now on the narrow part of the bolt and then it breaks. I think you need to find the nut end to see if the nut has backed off quite a ways or even come completely off.
Eric
Gearbox is good, spins freely and runs cool. No issues I am aware of and short of taking it apart.
Stump jumper is good and tight. Reinstalled this spring with new nut and cottar pin. Also new blades and bolts.
Eric
I use all metal lock nuts so I'd hope they are not backing off!!
I would like to find that part though to see what it looks like.
/ PTO Shaft to Gearbox Bolts Keep Breaking! #100
In post 17, you say "They use a spring plate instead of individual springs. Both are properly adjusted and if anything adjusted slightly on the loose side."
First, I have no familiarity with slip clutches. There seems to be a consensus that movement is either at fault or a contributing factor. If the bolt tension is on the loose side, it may allow the rotating parts to move a little relative to each other. If the bolts are tightened to spec (or overtightened) , I'd think the only time there's a chance of that sort of movement is when the equipment encounters something that causes the slip clutch to slip.
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
2019 ATLAS COPCO QAS 25 T4F NB-3 PHASE GENERATOR (A60429)
2019 ATLAS COPCO...
2006 Ford F-550 Flatbed Truck, VIN # 1FDAF57PX6EB82087 (A61165)
2006 Ford F-550...
2014 Freightliner M2 106 Palfinger PK22002EH 6 Ton Knuckleboom Flatbed Truck (A55973)
2014 Freightliner...
NEW HOLLAND T4.75 POWERSTAR TRACTOR (A62130)
NEW HOLLAND T4.75...
TOYOTA FORKLIFT (INOPERABLE) (A60736)
TOYOTA FORKLIFT...
