Driving over a septic tank
   / Driving over a septic tank #41
when I was young, the old-timer concrete men told me when concrete is poured, the first 50 years it slowly gets harder, the second 50 years it is in the softening/degradation stage.
The qualifier is; what concrete "recipe" was used. I've seen 5 yr-old concrete crumbling already.
Sounds like Michigan roads to me... Crumbling concrete.
   / Driving over a septic tank #42
I read somewhere that falls into septic tanks are often fatal. Naturally, this surprising tidbit was hard to get out of my mind for a while. And, now, here it is again.
   / Driving over a septic tank #43
Maybe fatal but certainly stinky....lol
I guess it would depend on the size if the tabk itself howver. Large commercial sized ones you could certainly fall into and maybe get stinky and drown in but the size I have (1500 gallons) would be hard to fall into and expire.
   / Driving over a septic tank #44
Why complicate things! Is'nt any place else to ride your piece if equipment ? Are you that short of land!!!!
I have no shortage of places to ride the tractor. I bought a ZT a few years ago because I hate cutting grass and I had over 20 trees to deal with. But things have changed.
I still hate cutting grass. But after the last ice storm, about 1/3 of the trees are too damaged. Another 1/2 are useless trees that can be removed. So, was considering getting a finish mower for the tractor. The tractor has a cab with AC so that is attractive.
I am going to map out the tank and see if I can mow over it while keeping the machine off the area and reaching in from the sides. Another option is to use a flail mower with hydraulic offset.
Getting rid of the trees also cuts the amount of leaves I need to deal with.
I like the idea of making a small island with plants like in post 40. That solves the problem.
Hope that helps you understand.
   / Driving over a septic tank #47
If your septic tank was at proper depth, if simply driving a car/tractor over it causes it to fail, then it is/was a weak, failing septic tank anyway. You’ll just bring it’s poor condition to your attention a bit sooner😁
   / Driving over a septic tank #48
I don’t think good 50 year old concrete “softens”. It always gets harder but at a minuscule pace after 50 years. I think what you are describing is the concrete getting brittle, and breaking apart.
   / Driving over a septic tank #49
What is “proper” depth? Around here any dirt covering the top is proper depth.
   / Driving over a septic tank #50
Here’s a picture of a pretty standard septic permit for my area. The leech field is dug 18 inches deep. The pipe is installed on top of 3 inches of gravel so it’s really 15 inches deep. The outlet on the tank is 13 inches under the top of the tank. Code requires the first bed to be at minimum 4” of slope from the tank. Digging the beds deeper isn’t allowed and that’s non negotiable terms. The only way to get more fall to the beds is move them farther down the hill but septic systems take up a lot of room and we’re frequently fighting for every inch of ground possible to get the required footage in while maintaining the property line setback, the structure setback and maintaining the duplicate area so moving down the hill 20-30 ft to get more fall just isn’t possible. So what I’m saying in more words is the septic tank is frequently set with just a dusting of dirt over top and that’s really the only option.
2001 John Deere M665 60in Zero Turn Commercial Mower (A59228)
2001 John Deere...
2019 MACK GRANITE (A58214)
2019 MACK GRANITE...
1770 (A58375)
1770 (A58375)
2019 CATERPILLAR 299D3 XE SKID STEER (A60429)
2019 CATERPILLAR...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59905)
2019 INTERNATIONAL...
Bobcat T66 (A60462)
Bobcat T66 (A60462)
