Bush hog gouging
/ Bush hog gouging #1
apeckham
Mahindra 2638
I am running 6 ft woods mower . When I am mowing and make a turn the sides dog into the ground and removes a strip of grass. I levaled it side to side . Have it pitched higher in the rear. I've tried raising the mower up thinking that maybe I'm mowing too low , but then it doesn't cut very well.
Anyone have any other ideas? Tia
/ Bush hog gouging #2
Are the side deck skids missing? The bolt onto the side skirt of the mower.
My mower broke a skid and it would gouge the dirt, scrape off grass, too.
/ Bush hog gouging #3
Where do you get cheap skids?
The manufacturer of my cutter wants $60 for a pair; the place they're supposed to be is pretty smooth so I'd be surprised if the skid shoes do much better job
/ Bush hog gouging #4
Mine were $95 each from Deere. I replaced them both.
/ Bush hog gouging #6
I replaced the worn out skid plates on my King Kutter. I made them from ¼" thick 2" wide flat bar stock. I had to take the cut to length pieces to a guy with a press-brake to have them bent to shape, then I drilled the mounting holes and used flat-head bolts.
I was working on my KK today, tightening bolts and readjusting things; going to have to replace the entire yoke and rear wheel this winter, it takes a beating. Those 20 yr. old skid plates are only slightly worn, but my soil ranges from loam to good-ole top soil.
Transfer Tank and Pump (A61166)
Transfer Tank and...
2015 FORD F150 4X2 PICKUP TRUCK (A59908)
2015 FORD F150 4X2...
New/Unused Landhonor Quick Attach Pallet Forks (A61166)
New/Unused...
2005 CASE 580 SUPER M SERIES 2 BACKHOE (A62129)
2005 CASE 580...
Batwing Rotary Mower Tractor Attachment (A61567)
Batwing Rotary...
UNUSED JCT HYD TREE/POST PULLER (A62131)
UNUSED JCT HYD...
