Bush hog gouging
/ Bush hog gouging #1
apeckham
Mahindra 2638
I am running 6 ft woods mower . When I am mowing and make a turn the sides dog into the ground and removes a strip of grass. I levaled it side to side . Have it pitched higher in the rear. I've tried raising the mower up thinking that maybe I'm mowing too low , but then it doesn't cut very well.
Anyone have any other ideas? Tia
/ Bush hog gouging #2
Are the side deck skids missing? The bolt onto the side skirt of the mower.
My mower broke a skid and it would gouge the dirt, scrape off grass, too.
/ Bush hog gouging #3
Where do you get cheap skids?
The manufacturer of my cutter wants $60 for a pair; the place they're supposed to be is pretty smooth so I'd be surprised if the skid shoes do much better job
/ Bush hog gouging #4
Mine were $95 each from Deere. I replaced them both.
/ Bush hog gouging #6
I replaced the worn out skid plates on my King Kutter. I made them from ¼" thick 2" wide flat bar stock. I had to take the cut to length pieces to a guy with a press-brake to have them bent to shape, then I drilled the mounting holes and used flat-head bolts.
I was working on my KK today, tightening bolts and readjusting things; going to have to replace the entire yoke and rear wheel this winter, it takes a beating. Those 20 yr. old skid plates are only slightly worn, but my soil ranges from loam to good-ole top soil.
John Deere 4520 (A60462)
John Deere 4520...
John Deere Hood Guard (A63116)
John Deere Hood...
UNUSED ATS T460 STAND ON SKID STEER (A62130)
UNUSED ATS T460...
2005 CATERPILLAR 247B SKID STEER (A62129)
2005 CATERPILLAR...
2024 GD Yatian LY05A Model T Replica Electric Cart (A61569)
2024 GD Yatian...
2012 Freightliner Cascadia (A63118)
2012 Freightliner...
