Safe way to raise a 30' pole
   / Safe way to raise a 30' pole #21
I shudder at the loads one could place on the front axle casting with that set up.
"honey, step up on the back of the mower deck, I just can't lift this load, and need a bit more ballast out back!"
That's one good thing about having limited hydraulic power, keeps me from tearing stuff up....
   / Safe way to raise a 30' pole #22
I set my trusses by myself. 24x24 garage/storage addition. I'd set them in upside down on the walls, one side then the other. Then I'd swing the pointed top up onto a step ladder. Then use a long 2x4 to push it the rest of the way up and over to lean onto the previous one. Worked really well. Wife came home and she was kinda surprised I'd set them all without assistance. So was I! :ROFLMAO:
   / Safe way to raise a 30' pole #23
Lol… the first one must’ve been tricky, tho!
   / Safe way to raise a 30' pole #24
I leaned it against the existing back wall of the garage I was extending from. Once it was locked to that back wall and the new side walls, I did the next one and so on. Having that existing building was like having a helper. :)
Swing a truss.
Move a ladder.
Tack in place.
Repeat xteen times.
   / Safe way to raise a 30' pole #26
I made a short 3 min video of how I raised my 25 ft flag pole. The pole it steel and heavy.
Very cool! Reminds me of the towers for the lead-in lights at the airport that are hinged to lay down for changing bulbs (except they have permanently attached boat trailer winches with cables since they have to do the operation on a regular basis).
   / Safe way to raise a 30' pole #27
Look up on How to raise a boat mast. It’s pretty easy. Just need some strength or a small hand winch / come along.
   / Safe way to raise a 30' pole #28
I raise a 25 foot pole every weekend. Well... the good ones, anyway. :ROFLMAO:
But ours are aluminum or spruce, not schedule 40 pipe! Probably a good bit lighter per unit length, even with the spreaders and halyard hardware.
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
2010 Ford Fusion Sedan (A59231)
2010 Ford Fusion...
2024 CATERPILLAR 305 CR EXCAVATOR (A60429)
2024 CATERPILLAR...
2012 DOOSAN G25 GENERATOR (A55745)
2012 DOOSAN G25...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2008 Bobcat S250 Compact Wheel Loader Skid Steer (A59228)
2008 Bobcat S250...
