OIL VISCOSITY
/ OIL VISCOSITY #1
Williy
Elite Member
Texas
Yanmar YT 235C Yannar YRC 60 rotary cutter, Yanmar RT72 rotary tiller B75 Backhoe & bucket & thumb, LS land grader
hAPPEN TO RUN ACROSS AND THOUGHT SOMEONE MIGHT LIKE TO WATCH THIS
willy
/ OIL VISCOSITY #2
Hydrodynamic Separation…
Fortunate for me most of my engines used 40 weight non-detergent…
/ OIL VISCOSITY #5
The curve in the video was interesting. Also, based on the additive package and what product it's used in, the shearing of the oil molecules is a factor. By wearing out the additive package you leave behind the base stock and it wears out even quicker. Hence in some product applications you would want to change to oil more often. We are seeing this especially in the 6 speed Honda Pilot and Ridgeline transmissions. It is a factor. Oil testing shows that the DW-1 wears out and allows more wear to occur (iron content increases). Then as time passes you wear out parts within the transmission UNLESS you change the fluid more frequently. This is the shearing of the additives and then by increasing replacement frequency it keeps wear low. Thin oil vs mechanical application.
/ OIL VISCOSITY #7
I was given the nickel tour of a shop that rebuilt Porsche transaxles. They showed me how Red Line oil broke down into separate semi-solid additives and a thin lubricant. Kept that shop busy. Guess what brand of lubricants I don't use...
/ OIL VISCOSITY #8
Yah…….right 😬
Early Ford spec 40 weight non detergent.
Switching to detergent in a motor with decades of non detergent puts the oil pan deposits in suspension and without oil filters problems develop…
/ OIL VISCOSITY #9
Read in one of the hotrod magazines back when the manufacturers first started specifying the very low viscosity oils. The story was that to increase the fuel economy on the dyno, the manufacturers were using sewing machine oil in the engines. The EPA caught one of them, then checked the others. All were running very low viscosity oils. To avoid fines, the manufacturers all said they were planning on switching to the low viscosity oil the next year.
New/Unused 20x30 All Steel Carport (A61166)
New/Unused 20x30...
(2) 30 Yard Dumpsters (A61166)
(2) 30 Yard...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A56438)
Kuhns AE10 Small...
(2) ROW PLANTER (A62130)
(2) ROW PLANTER...
iDrive TDS-2010H...
2006 Ford F-150 Lariat (A57148)
2006 Ford F-150...
