/ Your last generator Maintenance Run #7,442
Serviced my neighbour's Honda eg650 generator today. Unknown hours, but runs great and makes power, albeit a few hz high. It’s a cool little gem …
Interesting bit of history Robin.... thanks for posting that.
Probably ran plenty of AC drills, back before good cordless ones came along. Even has a DC output. I'm not used to seeing AC fused, but that might have been a space-constraint issue....
Rgds, D.
Power went down, about 10 minutes ago. 7200+ affected, no cause or ETA yet.....
No gen yet (my choice), but clock is ticking......
Rgds, D.
Power was down for about 1 hour. "Tree contact" is the listed reason. (Likely stragglers from recent ice-storm).
I'll take it.... but the area affected was widespread..... Things that Make You Go Hmmmmm......
Rgds, D.
Local media reported late-afternoon........ an Osprey had started to build a nest, on a main feeder-line into this area..... explains the wide-span outage, with no rough weather today.
Rgds, D.
/ Your last generator Maintenance Run #7,447
last time they got serviced??? ---- well lets see, I think it was 2 years ago when I last used 2 of them and the other 6 not since the former owner used them! LOL!!
One came on the service truck and I do use it a lot out in the field. I changed oil in it a couple times. Handy to have with me to grind drill weld. it will run my 225 ac welder for emergency welds out in the weeds and saves draggin stuff back to the shed to fix.
The ones for the house never get used so they been sitting 15 years now,--no time to mess with them!
/ Your last generator Maintenance Run #7,448
I wouldn’t worry about them too much 😁
Thanks for stopping-by Sonny. Looks like you build things.... carb rebuild or swap ? .... There is that Time Thing though :cool: , Roger That....
Rgds D,
/ Your last generator Maintenance Run #7,450
Well heck went all through the winter without a power outage. Just sitting here and at 2:24 the power just shut off. Drove down and checked at the neighbors and they were out also, so back up and reported it to National Grid. At that time they were just reporting 5 out of service, now it's 353. Then a bit later find out a milk tanker has rolled over in some S turns up the highway about 4-5 miles. So down and started the ol IH574 and backed the generator up to the house and hooked up and purring away. Projected restoration is 7PM today we will see how they do.
Edited to add; found out that the UPS on my Starlink, network switch and modem is good for 45 minutes.
Sounds like (should tempt murph, 3930.....) you should be back b4 long Lou.....
No crying over spilled milk, and you got to test the UPS too ! (y)
Rgds, D.
/ Your last generator Maintenance Run #7,452
Well a quarter to 8 and Nat Grid is reassessing the situation old IH just purring away;
Edited; now 10PM
Edited again; they actually beat the estimate 9:30PM power back on and transferred over and shut down the tractor, move her in the morning. Time for me to head back and call it a day.
/ Your last generator Maintenance Run #7,454
yes, really glad the old girl got a workout. Fulfilled its purpose, helping out on the farm.
Why EMC/I matters...... at about 12 minutes in, you can see (allegedly, there may have been more gens around) what happened to sensitive HF receivers when an HF gen lit up.
Not slamming HF, and this use-case only matters to a tiny-slice of the gen-pop.....
Rgds, D.
/ Your last generator Maintenance Run #7,457
Just turned 1647hrs on my 1200/1500w Champion. The 1 Carbon Build up issue, now the Needle and Seat are leaking. New Carb time for $26 on Amazon.
My 3750 Champion, doesn't get many hrs now that I am 90% Solar, but it fired right up after winter storage. Use it for Power Tools only.
/ Your last generator Maintenance Run #7,458
Rgds, D.
Amazing he was receiving any signals on HF this time of the year with thunder storms overhead. I would be expecting to hear constant static crashes. To top it off, his rig is a QRP rig.
Getting up there on hours, so can't complain there. I rebuilt a Briggs carb on my oldest one before shifting to wet-storage, but it's hard to beat a complete carb @ that price.
Rgds, D.
2014 FORREST RIVER SALEM TRAVEL TRAILER (A55745)
2014 FORREST RIVER...
2023 Kubota M7-174P (Premium) 4WD Tractor - 400 Hours (A61307)
2023 Kubota...
2012 Kenworth T800 T/A Day Cab Truck Tractor (A55973)
2012 Kenworth T800...
2025 Ariens IKON 42 42in Zero Turn Commercial Mower (A59228)
2025 Ariens IKON...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A61307)
2023 Unverferth...
2019 BOBCAT E32I EXCAVATOR (A59823)
2019 BOBCAT E32I...
