People with rotary 3 point spreaders... does your tractor ever get corrosion issues?
   / People with rotary 3 point spreaders... does your tractor ever get corrosion issues? #1
AntiqueIron
NY
1968 Ford 5000, Gas 8 speed Preforce
I'm pretty well familiar with the way the spreaders themselves rot out- my concern is whether all that fertilizer, lime, salt, whatever winds up coating the back of the tractor.
I have a nice original tractor that I like to keep in good cosmetic condition. I could get a lot of use out of a spreader, but after seeing what salt spreaders do to trucks... I'm not exactly convinced they do more good than harm except for spreading seed, and maybe sand. I can budget one, but I'm on the fence about rust issues on my nice tractor.
Walk away, or will the ol girl be fine?
   / People with rotary 3 point spreaders... does your tractor ever get corrosion issues? #2
So long as your rotary spreader (3 point driven) come with the shield that prevents the spinner from spreading material forward, you'll be just fine. That and at least in my situation, when I'm done, the back of the tractors get washed off as well as the spreader but my spreader has a poly conical drum on it so I only have to wash the lower unit off and when I'm done, it gets fogged with a diesel fuel / motor oil mix.
Rotted out spreaders get that way because people never clean them out. Kind of like people that never wash their tractors either. My tractors are pretty old (2002 and 2001 vintage) but you can eat off the motors as well as the back ends. I hate filth, plain and simple.
Here is the 2001 unit...
That's a good looking setup! I too wash and wax my tractor. She's a tool, but I believe tools should be kept presentable and clean. Not to mention I also have sentimental attachment to my ol gal.
I'd probably think that spraying the hopper with a good non stick spray of some variety, or rubbing in some used ATF, before and after use would help. Good hand wash and spray wax on the tractor after would probably do the trick.
   / People with rotary 3 point spreaders... does your tractor ever get corrosion issues? #4
Whay I have and use is a jug of mixed diesel fuel and motor oil that I spray on my spreader after washing (same with my disc mower after I use it prior to stprage. Keeps the implements from corroding. The sprayer I use draws the solution from the jug with compressed air and sprays the solution on the implements via a siphoning action much like a paint spray gun works.
My units all get power washed and I use a foam cannon to apply wash solution.
I fond it interesting when someone posts a picture of their 'problem tractor' or implement and it's filthy beyond belief.
I'd be embarrased to post up a picture like that. How you take care of your rxpensive equipment is a dorect reflection of how you treat other things.
Wear and tear is one thing, unmitigated filth is another.
One thing I'd never do is take apart anthing on a filthy tractor. Not only do you get grimy, but the filth can get inside the machine and cause issues.
Everything I own and operate, vehicles included, stay as clean as I can possibly keep them.
   / People with rotary 3 point spreaders... does your tractor ever get corrosion issues? #5
Yes I’m getting corrosion on my spreader and rinse it off. I also rinse my tractor off and no problems there. I’m only using it for spreading fertilizer once a year on about 2 acres.
   / People with rotary 3 point spreaders... does your tractor ever get corrosion issues? #6
Corrosion is a non issue with a poly hoppered spreader so long as you clean the distribition parts. I don't rinse anything off, I hot water pressure wash them, including the tractors. The spreader I have had for 20 years is corrosion free and it stays in the equipment barn, inverted on a pallet when not used.
   / People with rotary 3 point spreaders... does your tractor ever get corrosion issues? #7
If you’re using anything corrosive in a spin spreader, you need to be borderline obsessive about cleanup after use
I pressure wash every nook and cranny in the spreader and the tractor. Neither of my tractors show any sign of corrosion after years of use, they are both over 10 years old, stored inside.
Equipment is so expensive these days, it pays to take care of what you have
   / People with rotary 3 point spreaders... does your tractor ever get corrosion issues? #8
I have a Herd M12 spreader that I use for fertilizer 6x per year. Yes, the tractor gets a lot of fertilizer all over the back end, whether actual granules or just massive amounts of dust depends on what I’m spreading, but it’s all nasty and corrosive.
I have a routine of blowing everything off with the handheld leaf blower first, then rinsing everything down with the hose, before leaving it in the sun or wind to dry. Then I spray all exposed metal surfaces (e.g. 3-pt ball joints) with WD-40 from a spray bottle that I fill from gallon cans… a can lasts nearly a decade.
Following this routine, I’ve never seen any rust anywhere on the back of my tractors.
   / People with rotary 3 point spreaders... does your tractor ever get corrosion issues? #9
30 years ago, I modified an old Fressori steel cone fertilizer spreader to spread a mix of coal ash & rock salt. Both are corrosive, but I store it inside and use a cover to keep out rain & snow when spreading. The only maintenance I do is pressure wash it at the end of the season. I used it behind my old L3430 and more recently my L6060. The only corrosion on the spreader is on the deflector plate, and that is relatively minor. Neither tractor has any.
The trick is to keep everything dry when not in use, rig a shield to keep the spread material off the tractor, and hose it off at the end of the season.
   / People with rotary 3 point spreaders... does your tractor ever get corrosion issues? #10
View attachment 3522702 View attachment 3522703
I bought a poly Bush Hog for spreading sand and salt. I haven't got to use it yet. I messaged Bush Hog about a cover, haven't heard back. Where did you get your cover?
   / People with rotary 3 point spreaders... does your tractor ever get corrosion issues? #11
I pressure wash and oil after spreading, but the left fender is trashed and going to get replaced. It appears that washing it just helped fertilizer get into the crevices. I've been thinking of how I could cover the back of the tractor with plastic.
   / People with rotary 3 point spreaders... does your tractor ever get corrosion issues? #12
I have to clean everything (spreader/tractor) after spreading lime, and or fertilizer. Or else corrosion starts. Better to clean, than fight corrosion.
   / People with rotary 3 point spreaders... does your tractor ever get corrosion issues? #13
YES! The tractor in my profile picture, a Ford 3000 diesel, is a very good example. It wasn't fertilizer that rusted it, but alum, which is almost as corrosive as salt IMO. I have a spreader identical to the one in the picture posted by bdhsfz6. I owned a broiler growout farm for 30 years. I spread 4800 pounds of granulated alum every 6 weeks, between flocks, 6-7 times a year to control ammonia in the litter. The alum was granulated, but had fines in it that made it very dusty. The back of the tractor was coated in this dust, and some of the granules when I got done, every time I used it. When done spreading, I always, and I mean ALWAYS washed the tractor and spreader thoroughly without fail. I didn't have a pressure washer at first, so I just used a garden hose and good nozzle. I got a pressure washer a couple years later, but it was only a cold water washer. The alum dissolved easily, and I thought I was doing an excellent job washing it. But, as HayFarmer mentioned, after a while I decided the water was just washing the stuff into the cracks and crevices around the back end of the tractor. I have pictures somewhere of the inside of the rear wheels, which is where most of the stuff landed, and where they were completely rusted. In April 2022 began a restoration job on that tractor, and the first thing I did was take pictures of everything before I started disassembling it. The rear wheels were the first thing I worked on. As it turned out, while the rust looked awful, and the paint on them and the whole back end of the tractor was gone, it wasn't really that bad underneath. None of the steel was damaged, but the paint was gone almost everywhere, replaced with rust. It extended forward to under the seat, on the brake and clutch pedals and linkage, footboards, etc. I disassembled everything, sandblasted what would fit in my Harbor Freight sandblasting cabinet, cleaned up the rest with wire wheel on a drill and angle grinder, and used rust converter where I couldn't get with sandblasting or tools. I primed everything before painting Ford blue, or Ford gray on the wheels, and as of right now, I'm about 80% done with the restoration. Everything is done from the seat forward. I've still got to prime and paint the back end, rear axles, and transmission. It's running and hopefully will be done this summer. From what I've seen of the pull-type fertilizer spreaders at the local farm supply plants around here, there's not much you can do to rust-proof them. I sold my farm and retired 4 years ago, so it's no longer an issue for me.
   / People with rotary 3 point spreaders... does your tractor ever get corrosion issues? #14
I used a heavy canvas fire pit cover:
Fits my 44" Fressori spreader perfectly.
   / People with rotary 3 point spreaders... does your tractor ever get corrosion issues? #15
When the trees fell on my old pole barn my spreader got smashed. The steel parts are rusted but not damaged, only the galvanized steel hopper is ruined.
   / People with rotary 3 point spreaders... does your tractor ever get corrosion issues? #16
Clean it thoroughly with soap and pressure, blow it off around cone bottom and spinners, oil it aggressively and store it upside down if possible.
The spreader I have is over 30 years old and has spread TONS of fertilizer and will spread lots more.
2010 MULTIQUIP 25KW GENERATOR (A55745)
2010 MULTIQUIP...
John Deere 5103 (A53317)
John Deere 5103...
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A56857)
2020 Caterpillar...
Groundsmaster 3500-D madel 30839 (A56859)
Groundsmaster...
500 BBL WHEELED FRAC TANK (A58214)
500 BBL WHEELED...
2016 CATERPILLAR 259D SKID STEER (A60429)
2016 CATERPILLAR...
