PTO
spring1802
columbus oh
4200 jd
PTO e160 mower not working
I can push the connectors together and it'll work and then nothing engine start and sometimes not
Could just be some corrosion in the pins and receptacle. I would go get some DeOxit (local car stores have it) and clean them and see if it works better.
/ PTO
Thanks a lot to check
Connector receptacle has 8 slot
The wiring looks fine
My JD F1445 has a similar relay. I have used find s paper or nail buffing type stick and cleaned it up before. Slid it in and out a few times and that worked. I have also seen a safety switch cause this, primarily the parking brake sensor. I was able to push it in and let it pop back out a few times and the issue went away. That happened mainly because I didn't set the parking brake and it pushed the relay in and just kinda hung in.
Well, the crank circuit runs through the PTO and brake switches via the purple wires. Those are what I see the connectors fail on the PTO switch. The B terminal on the key switch as well. That isn't to say that other terminals can't be affected which affect the PTO operation. Deere just uses cheap brass terminals on these and you pretty much need to take a pin tool and slide the connector out to see if they are corroded or broken. Or, even the PTO switch itself is funky.
Rhino 3-Pt. Forklift for Tractor (A66408)
Rhino 3-Pt...
2010 PETERBILT 384 (A65643)
2010 PETERBILT 384...
2024 CASE TV370B SKID STEER (A65053)
2024 CASE TV370B...
New/Unused Quick Attach Backhoe Attachment (A65583)
New/Unused Quick...
2014 Chevrolet Tahoe SUV (A64557)
2014 Chevrolet...
(2) Planter Boxes (A66408)
(2) Planter Boxes...
