Ethanol Free Gas
/ Ethanol Free Gas #181
For those who fill small jugs with ethanol free gas, keep in mind most gas pumps use the same hose to dispense all gasoline blends. The first half gallon or so will likely be the blend the previous customer bought. After selecting the ethanol free blend, it's best to put the first gallon or so in the vehicle tank to flush the hose before filling your jug.
Many gas stations have warning labels to this effect, but not all.
/ Ethanol Free Gas #184
Something I wish they had available in NS is corn free gas, can't get it anywhere. Even tried the local yacht club figuring boaters of all things would be after corn free....nope, not available.
/ Ethanol Free Gas #185
Before ethanol free gas was available here, I used synthetic fuel in my small engines. Expensive, yes, but it was worth it to me to avoid problems.
Not practical for automotive use though.
/ Ethanol Free Gas #186
I saw a gallon of that at Menards the other day. It cost more than a new carburetor for my chainsaw.
/ Ethanol Free Gas #188
Plenty of E0 stations here, but the one I buy from, ALL of their hi-test fuel is E0 and have it's own hose.
SR
/ Ethanol Free Gas #189
Call me cheap but what I do is run the corn gas all summer as I use my trimmer regularly and keep it full to the top. Come fall I'll run it dry and then fill it with the ridiculously expensive pre mixed stuff, run it for a bit, drain it back into the can and then run it dry. I do the same with stuff I don't use much, my hedge trimmer and my chainsaw.
A bunch of screwing around....yup, necessary....I don't know for sure but I intend to keep doing it. Being forced into using something that may/will cause harm to something I own because 'the goobermint says so" rubs me the wrong way but you got no choice.
/ Ethanol Free Gas #190
Have 89 BP 8 miles from house and 90 No-name Ethanol-Free less than 3 miles. BP is dedicated pump with just that product available, 90 octane pump has several choices available but it has a dedicated hose just for that product.
/ Ethanol Free Gas #191
Yep, follow the money. And no mention of fewer mpg with that crap.
No E15 here, but E0 is ~75¢/gal more than E10 so even if your mileage is a tad better you're not really ahead.
As I've noted before, I'll use E0 to make mix for 2 stroke engines, but any 4 strokes get E10. Never had an issue.
/ Ethanol Free Gas #194
Haven't checked E0 price yet. The last time I called a station with it the employee didn't even know they sold it :LOL: I'll pick up about 15 gallons for mowers, brush cutter, chainsaws, etc. I plan to burn a few tanks of E0 in the Mazda too, just for comparison.
/ Ethanol Free Gas #195
I’ve had problems with E10 corroding and forming deposits in the carburetor on my 4 stroke engines. I now go out of my way to buy ethanol free gas for anything I have with a carburetor.
/ Ethanol Free Gas #196
Good to know, but there are none around here.
Are you close to Clifford, PA? Paradise Valley plaza on 106 has ethanol free on it's own hose. Also, Lapera's in Royal on 106 has ethanol free. Full serve, so I don't stop there, but they have it.
/ Ethanol Free Gas #197
Why I run canned gas in my chainsaws. E-free is hard to get here and typically commands a premium price. Consequently, I always add stabilizer to it except in the buggy's where it gets consumed pretty quick. Bottom line is E-Gas sucks.
/ Ethanol Free Gas #198
fortunately E free premium is available here. given the amount of E free fuel i use (2 stroke & mowers) for farm & the place here in town, can't begin to imagine using the store canned fuel. way, way too expensive
2275 (A62131)
2275 (A62131)
2015 Ford F-250 Pickup Truck (A61567)
2015 Ford F-250...
2020 INTERNATIONAL MV607 (A58214)
2020 INTERNATIONAL...
2020 Broyhill Load and Pack Articulated Solid Waste Handling Vehicle (A59228)
2020 Broyhill Load...
Rogator RG1300C (A63118)
Rogator RG1300C...
UNUSED JCT 72" HYD TILLER (A62131)
UNUSED JCT 72" HYD...
