What is better than a kubota GR2120?
/ What is better than a kubota GR2120? #21
Not at those prices :( :eek: 🍻
Oh, you have a budget. Never mind, just keep what you have :)
Seriously though, if you're wanting something that cuts the time down and a ZTR isn't an option, then you're only other choice is running a bigger deck. I gave $6K for my 2008 F2880 with 2500 hrs on it, and I had to do some work to the back end. If I would have paid a dealer to do it, it would have probably cost me around $1k. My deck is only 72", but they have NO problems running an 84" deck at speed. The other option is a CUT or utility tractor with a belly mower or a 3 point finish mower.
If you look, you can find used stuff at a somewhat reasonable price. I bought a 2008 New Holland TC40DA in Jan for $17k because my old 1710 gave out on me. Transport cost from Arkansas to Indiana was around $1100. The cab was NICE for plowing snow, and the AC is even better for working in the summer. 40hp machines seem to fall into a crack where they are either bigger than most people want, or too small for farmers to mess with. There were several other TC40s of similar vintage and hours that were in the $12k-$16k price range, but this was the only one with a cab (DA model). There were also some 30-35hp machines available in that price range.
thanks for all the replies, possibly should have looked at the Cub but just had trouble believing it wouldn't slide on the slopes when dry or damp :cautious:🍻
The headlights are all but useless, so if you really need to use it in the dark you would probably have add aftermarket lights. The seat is comfortable, but if you have very rough ground, you may wind up unplugging the seat switch because it is ultra-sensitive (see my thread on the CC ZTXS5 54 for good, bad and ugly report on this mower).
I will say that mine is rock-solid on slopes.
is that up , down and sometimes sideways ?
/ What is better than a kubota GR2120? #24
All the above. I mow a big, long 25 degree side slope and also have to turn circles around fruit trees on a 25 degree slope. Never feels tippy, maintains directional control and doesn't lose traction, even turning the circles.
I can even back up these slopes, which is something I could never do with my lawn tractor without losing traction. It will also do all of this with a triple-bagger full of grass or leaves on it.
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2016 Ford F-150...
2012 DIAMOND T TRAILER TRAILER (A58214)
2012 DIAMOND T...
2017 Wacker Neuson LTV6 Towable Light Tower (A56857)
2017 Wacker Neuson...
CAT 930M (A58214)
CAT 930M (A58214)
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2018 Ford F-150...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
