JeepHead
- Joined
- Jul 13, 2023
- Messages
- 1,290
- Location
- The hills of Southern Indiana
- Tractor
- Kubota 2502H, HSI Pinnacle grapple, LP 48" forks, LP 60" BB, KK tiller 60", KK middle buster, Pat's QH
Disclaimer: Never did one.
I thought most above ground pools were built on a sand base. If that's the case, I'd make sure the remaining high point was at least an inch or two below the desired finished elevation. Then I'd set up screeds, bring in the sand and screed it off. With the screeds set parallel to the long side at 8' centers, you could get by with setting the first one so a 12' 2x4 would do the first 8' swath plus the part of the 2x4 that hangs beyond the first section could level the extra 3' beyond.
the legs sit directly on the earth, the sand base goes inside the walls under the liner. And the directions state to not build up to elevation, but to cut down to elevation so that you have firmly compacted earth under the legs. And a perfectly straight 2x4 is about all I could come up with for leveling such a wide area. I really do like the grade stakes to help with cutting. I am now looking into one of those aluminum 36" rakes to help moving material. I think I could wet the ground a bit to help in making it easier to cut.
